NSPanel Pro v4.3.0 Officially Released: New Features & Enhancements
Dear NSPanel Pro Users,
Thank you for your continued attention and support! We are pleased to announce that the NSPanel Pro V4.3.0 firmware has been officially released. This update focuses on enhancing NSPanel Pro’s integration with mainstream open ecosystems, upgrading the thermostat capabilities, and bringing a variety of new features that improve usability and customization.
New Features Overview
1.Core Features
  • Matter Bridge Chapter 3: NSPanel Pro can now act as a Matter Bridge, supporting the connection of non-Matter devices from Home Assistant to third-party Matter ecosystems, enabling cross-platform control.
  • Central Heating System:
    We have significantly upgraded the thermostat functionality. You can now centrally view and manage multiple heating zones through NSPanel Pro’s dedicated Central Heating screen, achieving intelligent whole-house heating control.
2. Additional Features
  • Expose NSPanel Pro to Home Assistant via MQTT: NSPanel Pro can now expose its own capabilities as entities to Home Assistant through a configured MQTT broker. This includes:
    • Speaker: NSPanel’s speaker is now exposed in Home Assistant, enabling startup volume adjustments.
    • Screen & Sensors: Control screen wake/sleep, adjust brightness; read ambient light sensor data.
    • Smart Security: Arm/disarm remotely.
    • Basic Status: Online status, IP address, and other information.
  • Interaction & Notification Optimization**:
    • Device card interaction optimized: Tap the icon to control on/off; tap elsewhere on the card to enter details.
    • Notifications support custom ringtones and message content
    • Support for disabling system startup sound
  • Zigbee Mode Switch Optimization: Switching between Coordinator and Router modes no longer requires resetting the device.
  • Thermostat Function Enhancement
    • TRV devices are supported in the thermostat split-screen for display and control
    • Temperature adjustment precision supports 0.1°C increments
  • New Device Support: SONOFF S61s, S41s smart plugs and MINI-ZB2GS stepper controller.
3. Bugfix
Several known issues have been fixed, improving system stability.
This release implements the features outlined in our product roadmap. Please refer to NSPanel Pro Roadmap and Co-Created Future - NSPanel Pro - eWeLink Forum for more details.
Detailed Operation Tutorials
To help you quickly get started with the new features, we’ve provided detailed step-by-step guides for each major feature, including both eWeLink App and NSPanel Pro screen operations. Please ensure your NSPanel Pro has been upgraded to v4.3.0
Note:
  1. v4.3.0 is a beta release for selected devices. If you would like to experience the latest features, please join through the NSPanel Pro v4.xx Beta Test Application Tool.
  2. Please ensure your App version is v5.22.1or above.
    The current eWeLink App v5.22.1 was submitted to the Google Play Store for review on January 12th and is expected to support updates in about a week.
Tutorial 1: Bridging Home Assistant Devices to Matter via NSPanel Pro
Prerequisite: NSPanel Pro needs to be synced to a Matter ecosystem.
Please refer to NSPanel Pro v4.1.0 Release: New Features & Enhancements - NSPanel Pro - eWeLink Forum for more details.
App Operation Steps
  1. Accessing the Home Assistant feature:
    NSPanel Pro > Settings > Home Assistant to enter the feature.
  2. Configure and Connect to Home Assistant:
    Search for Home Assistant on the local network (or click “Manual Configuration” to enter the Home Assistant IP) > Enter the port number > Click “Configure” > Redirect and log in to your Home Assistant account.
    After successful login, devices and entities from your Home Assistant platform will be displayed in the eWeLink App.
  3. Bridge Home Assistant Devices to Matter
    Click Edit > Select devices/entities (multiple selection supported) > Save. After successful sync, devices will be synced by default to the Matter ecosystem that NSPanel Pro has already joined.
  4. View Sync Status and Control Devices:
    Once the sync is successful, you can view the sync status in the App and control devices via the Matter platform.
Tutorial 2: Using the Central Heating System
App Operation Steps:
  1. Enable the “Central Heating System”:
    Click the NSPanel Pro device card to enter the details page. NSPanel Pro > Details Page > Screens > Click the icon in the top right corner > Add "Central Heating" to the Displayed section > Save.
    Supports reordering the “Central Heating” screen.
    After saving successfully, you need to go to the NSPanel Pro device to view the Central Heating screen and configure/use it.
NSPanel Pro Screen Operation Steps:
  1. Enable the “Central Heating System” (If you have already enabled it via the eWeLink App, you can skip this step):
    Pull down the menu > Settings > Thermostats > Central Heating Button, toggle the “Central Heating Button” setting to enable, then go to view the Central Heating screen for configuration and use.
  2. Initial Configuration:
    Central Heating screen > Add. Configure according to the on-screen content:
  3. Subsequent Use:
    a. Long press the thermostat card to enter the thermostat UI control interface.
    b. Set the temperature, switch operating modes,etc.
Tutorial 3: Exposing NSPanel Pro to Home Assistant via MQTT
Note: If you have already configured an MQTT Broker via the eWeLink App before this version, after upgrading to v4.3.0, NSPanel Pro will automatically connect to the configured Home Assistant.
Please refer to: https://forum.ewelink.cc/t/nspanel-pro-v4-1-0-release-new-features-enhancements/206443
  1. In the App, go to NSPanel Pro > Device Settings > Home Assistant > Click Get Started. After completing the MQTT Broker configuration,NSPanel Pro will automatically connect to the Home Assistant platform previously configured.
  2. Once connected, you can view and control NSPanel Pro in Home Assistant. Supported functions include:
    • Speaker: Adjust startup volume.
No operation required.
Tutorial 4: Setting Custom Notifications
When Smart Security or Smart Scenes are triggered, notifications on the NSPanel Pro screen support configuration of custom ringtones and message text.
1. Smart Security
a. Click the NSPanel Pro device card to enter the details page. NSPanel Pro > Details Page > Gateway > Smart Security.
b. Click the security name to enter the configuration page. Alarm > Settings > Alarm Beeps > Choose > Custom Ringtone > Upload.
Redirect to the system folder, select the audio file. After upload completes, choose the corresponding custom ringtone, then continue completing other configuration for Smart Security.
2. Smart Scenes
Supports custom ringtones and custom message text as an execution action for Smart Scenes, triggering notifications on the NSPanel Pro screen.
Prerequisite: NSPanel Pro needs to be selected as an execution action for the Smart Scene.
a. In the Smart Scene configuration page, select NSPanel Pro as the scene execution action: Then > Smart Device > NSPanel Pro.
b. Configure Custom Ringtone: Alarm Beeps > Choose.
If pre-uploaded custom ringtones already exist, you can directly select one, or click Custom Ringtone > Upload.
c. Configure Custom Notification Message: Set the Pop-up Alert Button to enabled, Alert Message > Custom > Enter the alert message text you want displayed on the NSPanel Pro screen, then save.
Continue completing other configurations for the Smart Scene, then click Save Smart Scene.
d. Select the custom ringtone and edit the alert message.
e. Save the scene.
Tutorial 5: Custom Ringtone Management
You can upload custom ringtones for configuration in Smart Security and Smart Scenes, and manage the uploaded custom ringtones.
a. Go to NSPanel Pro > Device Settings > Ringtone.
b. Click Upload to upload a new ringtone file.
c. Click on an uploaded ringtone in the list to manage it, such as changing the ringtone name or deleting the ringtone.
Tutorial 6: Device Card Interaction in NSPanel Pro Device Screen
In this version, we have optimized the device card interaction within the device screen.
  1. Click the icon on the device card to control the device’s on/off state.
  • Single-channel device: Click the device icon to control the single-channel switch.
  • Multi-channel device: Click the device icon to control all channels of the device, turning all on or all off.
  1. Click the blank area of the device card to enter the device details page and control functions other than the on/off switch.
Tutorial 7: Others
a. Disable System Startup Sound: Top drop-down menu -> Settings -> Volume -> Start Sound to Off/Disabled.
Bug Fixes & Gratitude
In the v4.3.0 release, we’ve fixed several issues reported in the community forums. Special thanks to users who provided valuable feedback on our community forum. Their reports helped us quickly identify and resolve these issues. Below are some of the fixed bugs with their respective feedback links:
  • Improved device tiles with clearer status indicators and more intuitive tap interactions.
  • Screen sleep/wake and screen saver settings now work consistently across all apps on NSPanel Pro.
  • Added an option to mute the startup sound.
  • Improved TRV support on NSPanel Pro, including:
    • Display and control in the thermostat screen view.
    • Enhanced tile information for current status and target temperature.
  • Reboots are no longer necessary for smoothly switching between Zigbee Hub Mode and Zigbee Router Mode.
  • Temperature adjustments for Thermostat are now more precise when configured in the eWeLink App.
We sincerely thank all users who reported issues! If you encounter any new problems after upgrading, please feel free to post in the forum or contact our support team. Your feedback is the driving force behind our progress.
Conclusion
The v4.3.0 version further solidifies NSPanel Pro’s position as the core of smart home control by introducing the Central Heating system and enhanced ecosystem integration capabilities. We continue to optimize the basic experience, fix known issues, and strive to provide you with a more reliable and feature-rich product.
If you encounter any issues during the upgrade or usage process, please feel free to discuss them with us in the forum. Your feedback will help us continuously improve NSPanel Pro.
Thank you for your ongoing support.
The NSPanel Pro Team
What if you did it the other way around, those buttons? The vast majority want to turn on the lights. The controls are clunky, when I want to turn on the light I have to press a small icon, if I don’t do it right, an annoying table appears.
Let’s try to summarize the interaction methods described for Home Assistant. What you call export to or from Home Assistant has absolutely nothing to do with exporting anything.
Without any hostility, I’d like to point out that the eWeLink dev team uses the word “export” in their own very specific way. More importantly, this meaning does not match how the Home Assistant community understands the term. MQTT ≠ Export. MQTT is a Home Assistant integration that:
  • subscribes to topics,
  • publishes states,
  • creates entities on the HA side,
  • does not require any kind of “export” from the device.
MQTT acts as a transport layer, not an “export” mechanism, because nothing is being “exported”. Home Assistant simply receives data, and that’s it. Using the word “export” here is confusing and misleading, because the concept of “export” does not exist in the worlds of HA, MQTT, or Zigbee. That’s why it looks absurd when you read it from that perspective.
Furthermore, “Syncing Home Assistant Devices to Matter” means that the NSPanel Pro can expose devices coming from the eWeLink Add‑on to Google Home / Apple Home / SmartThings via Matter — not that it synchronizes with Home Assistant through Matter. The NSPanel Pro does not use Home Assistant’s Matter integration, nor does it act as a Matter controller for HA. Instead, it simply takes entities provided by the eWeLink Add‑on and re‑publishes them to external ecosystems as a Matter bridge.
Home Assistant itself is fully capable of exposing its own devices to Matter using the native Matter integration, without any involvement from the NSPanel Pro. In this setup, HA is the Matter controller and communicates directly with Google Home, Apple Home, or other Matter ecosystems. The NSPanel Pro plays no role in that process.
Therefore, to describe the situation accurately: in the eWeLink workflow, Home Assistant is only a source of entities for the NSPanel Pro, not a participant in Matter. The NSPanel Pro’s Matter sync is entirely separate from Home Assistant’s own Matter capabilities.
@jam3 Thank you for your detailed and professional feedback, which helps us prevent misunderstandings in technical communication.
You are absolutely right. Using “Export” and “Sync” to describe MQTT integration and Matter bridging functions can indeed be confusing. We will correct these terms.
The role NSPanel Pro plays here is that of a Matter Bridge. Its core value lies in bridging your existing non-Matter protocol devices in Home Assistant into the Matter ecosystem. This is a parallel and complementary path to Home Assistant’s own function as a Matter Hub/Controller for managing native Matter devices. We are not replacing with HA’s native capabilities.
Thank you again for your valuable input.
Best regards
Hi,@Jojkoba Thank you for sharing your experience.
Our team has noted this feedback and has begun evaluating options to adjust the interaction design.
I would like to have the speaker as an entity Audio output. To configure audio Alarm announcements
It’s really inconvenient to control, just swap the functions in the button and it will be fine. What you did only makes sense for a 2 - 4 relay module.
Thanks for joining me as I had proposed about this feature as well. I have noticed that, especially with Home Assistant. The NS Panel Pro is not exposed to the Media area where one can configure text to speech messages.
For example I wish the Ns Panel Pro will be able to announve the Alarm is now disarmed, or One can even have custom.audio messages such as The door has been left open while the alarm is activated etc.
Thank you, and likewise :slight_smile:
I suggested something like this in another thread. I want to toggle the light/switch more frequently than I want to change its settings, so have the small button take the user to the settings page.
Thank you for your feedback. We plan to support this feature in the v4.4.0 release, which will allow you to control the NSPanel Pro speaker to play audio files from Home Assistant.
Thank you for the detailed demonstration and explanation. The team is actively evaluating solutions to address this issue.
Please work on Alarm syncing as well. When HA Alarm.is Armed through Alarmo, NsPanelPro does not Arm, but remains disarmed.
Hey, for me, this is a breakthrough software version. I was waiting for better support for TRVZB heating valves, and it’s here. I’m testing version 4.3 with them and the PRO panel - so far, I have no complaints.
Good job!!!
I was very pleased to see the fine adjustment of the temperature tresholds in the thermostat.
However if I changed it from 0,5 Celsius to 0,2 or 0,3 it triggers a multiple on-off actions on the actuator.
Even if i changed back to 0,5 Celsious it still happening every time the thermostat swith on or off.
I am very worried, that this behavior damages the actuators and waterpumps.
Please help ASAP!
It seems to me the problem occurs when the thermostat is in automatic mode. When I switch it to manual mode it seems to be ok. However this is no solition to me.
Thanks for your help.
Ok. I maybe figured out what happend. The new firmware fully reset all my shedules in the automatic mode.
It is very inconvinient, but I hope it explains the problem.
Here is an extra bit to the story.
There are two thermostat configured in my nspanel pro: one for the ground floor and the other for the first floor.
When I adjusted the treshold(±0,3C) in the first floor thermostat, it messed up my shedules in the automatic mode (again). However, when I made the same adjustment in the ground floor thermostat, the shedules remained untouched.
My NSPP went completely offline again. Lost all the communication and devices, while ZBBridge part ot the network is just fine.
I am really tired of this (NSPanelPro) device. It is unreilable. I waited till 4.3.2 to upgrade, but it did not help.
Device is 100km away and it is freezing right now. :-((((
I apologize for this issue. May I ask if the NSPanel Pro’s Wi-Fi connection has been disconnected? If the device is not with you, you can try restarting it remotely via the app. When you have the device with you, please check the network and submit the NSPanel Pro logs. I will work on identifying the problem ASAP.
