I had previously removed these devices from the NSPanel Pro due to persistent system crashes. After updating to version 4.3.0, I will be adding them back. If any further crashes occur, I will send the daily reports and keep you informed."
Did you fix the error in nspp that caused the matter bridge to not work in iHost?
By the way, Iâm glad you got the products and tested them. Has the issue you identifiedâwhere they go offline without manual additionâbeen resolved yet?"
I added the devices to the NSPanel Pro 120 again before performing the update, but it rebooted itself and has now entered a reset loop. I have already submitted feedback for the first two resets and have attached the photos. I have also shared the daily logs generated after the reset. Additionally, please note that CPU usage increases significantly during this reset loop.
Hi, we just released v4.3.0. You can check the update on NSPanel Pro, or wait for some time and then eWeLink App will show an update for NSPanel Pro is available.
Thank you very much for the feedback. We are going to look into it ASAP.
No, we got the logs and are working on it.
These are similar issues as reported by @serkandemir1989 and other users. We donât quite understand the root cause, but we are working on it. Please bear with us.
I managed to update the NS Panel.Pro. congratulations! When will.you push a similar update to the NSPanel.Pro 120?
The 120 seems to be behind on firmware updates and still not functional.in Home Assistant.
Did you manage to replicate this error or is the problem with me?
I have nspp 120 and I already have update 2.3.0
I updated my device to version 4.3.0. Previously, I could turn devices on and off with a single tap on the button. Now, when I tap the button, it opens a new page and I have to tap again to control it. Alternatively, I have to aim perfectly for a tiny icon inside the button to toggle it in one touch, which is very time-consuming. How can I restore the one-touch toggle functionality for the whole button like it was before?
Sorry. Not true. My NSPanel Pro just successfully updated to 4.3
It interacts well with HA
Am I just lucky ?
PS. Response to Alysuph
My NsPa el.Pro is updated to V.4.30 but the NsPanel Pro 120 still on 4.1.5.
I was asking about the NsPanel Pro 120
Do you in beta testing?
No, is it necessary?
I am registered as a beta tester for nspanel pro. I donât know if that has anything to do with this case.
All three nspanel pro stuck at updating to 4.3.0.
Link to video iCloud Photos - Apple iCloud
