NSPanel Pro v4.1.0 Release: New Features & Enhancements
Tried restarting nspanel pro but it didn’t help. :slight_smile: By the way, those sensors didn’t work from the beginning after upgrading firmware.
It restarts whenever I want. I wanted it as a replacement for iHost but the miracle is that at least the display is on / off.
For me everything works quite well :slightly_smiling_face:
I’m running three NSPannel Pro units, with 40+ Sonoff devices and around 10 third-party Zigbee devices (for example Sunricher Zigbee).
I’ve been using this setup for over a year and never had any issues so far. Also matter bridge with Apple homekit works pretty good, better than raspberry pi5+homebridge+ewelink plugin.
Maybe regarding issues and headache TRZVB a bit annoying, cant update, child lock resets itself afterwhile… :smiley:
Secondo me è importante poter cambiare rapidamente la modalità del termostato tramite “scene”.
Ad esempio: Se premo un pulsante (switchman R5), allora termostato è disattivato.
Spero questa funzione sia un giorno implementata
Please assist. Ihave run out of memory. Device ID. 10020401bf
Hi, after restarting the NSPanelPro, could you please try to sync the SNZB-02P again? Also, could you submit the NSPanelPro logs right after the restart (via Screen Pull-down > Settings > About > Submit Logs)?
Hi, I’m sorry you’re encountering this issue. Please refer to the solution provided in the linked reply. If it doesn’t resolve the problem, or if you have any other questions, please feel free to let me know.
Hi, how to turn off touch debuge mode ?
When will we be able to install or update NS Panel Pro remotely? It is a challenge, if not a pain in the “us” flr remote sites.
This feature has been implemented in version 4.1.4. If your device has not received this version, please use the Beta tool to join the whitelist and obtain it:
:memo: How to Apply
Follow these steps to join the Beta Test program:
  1. Visit the tool page: NSPanel Pro Beta Testing Program
  2. Log in using your eWeLink account.
  3. Select the NSPanel Pro device you wish to register.
  4. Read and accept the risk notice, then submit your application.
  5. Wait approximately 5 minutes, then go to your device’s Settings -> About -> Software Update to check for the latest firmware and install it.
It requires the eweLink app (iOS 5.21 or Android 5.22.0) to function. If a new app version is detected, please update promptly to experience the feature.
Hi, This is the specific path: Advanced Settings → System → Developer options → Input → Pointer location. You can give it a try.
Thanks, It works, but you need turn on developer mode in system tap 7 times on Build number.
Restarted but I cant sync it because it is “yet not supported”
Great suggestion! We are developing a new Thermostat called Central Heating System. We will optimize existing Heating and Cooling thermostat after we release Central Heating System.
Hi, sorry for the issue. please refer to NSPanel Pro V4.0.12 impossible to complete update - #3 by MichaelLearnsToCode for how to clear the cache of NSPanelPro App.
Or you can click Check button on the alert and use password smatek@123 to manage the storage. You can safely delete files from /data/data/com.eWeLinkControlPanel/files/ota/.
PS: As a last resort, you can always do a Factory Reset. The cost is a bit high. You will need to do all the configurations again, including re-pairing Zigbee devices.
Hi, we have released version 4.2.2 to address the issue you encountered. Please check and upgrade to this version. If you have any further problems, feel free to contact me at any time.
It works!!! Thank you very much!
Hello Ewelink Team.
1 question :
Do you think, on next release, when the ability of the device will be available over zigbee.
or, directly from the device itself via your app.
using an IR sensor device ( i guess zigbee ) to wakeup the screen himself ?
why, this ask ?
because, to wake the screen for now, we must touch it, and for my case, where the NSPanel is located in the entrance hall of the house.
he will perfect to have the ability as suggested via zigbee for automation from HA, or with your integrated app.
i hope your understand…
Hi, thank you very much for using NSPanel Pro.
There are several methods to control the display of NSPanel Pro automatically:
  • Using NSPanel Pro’ Open API: https://help.sonoff.tech/docs/NSPanel-Pro-API (The Screen Display Functions have been implemented in v4.x firmwares).
  • Using Home Assistant Dashboard and Automation. This feature will be implemented in v4.3.0 firmware.
  • Using eWeLink Scenes (The controls of NSPanel Pro’s display as eWeLink scene actions): We don’t have a plan for this yet, but if there is strong demand, we could put it in eWeLink App’s roadmap.
Hello, thank you for your answer.
i’m not sure, if you understand my ask.
i mean to wake the screen ( simulate “touch screen” ), on API i see only to change setting screen, not wake.
on 4.3.0 i hope have this feature available, at least from zigbee ability ( to control from Home Assistant )
