NSPanel Pro V4.0.7 Optimized Version Released
Thank you for quick response.
This is the problem with tiles of devices displayed on NS Panel Pro. Before latest update temperature value was on the left and humidity on the right.
Now as you see humidity is on the left and temperature on the right.
They are reversed. Can you please bring them back to previous order?
Again thank you for quick response.
With all respect. I know how cast is working as I use cast from iHost on NS Panel Pro for very long time.
Never had any problems with it. Until recent NS Panel Pro update.
No matter what config I will use - iHost with remote access On or OFF.
Link to iHost cast - local or remote on NS Panel Pro.
The manual scenes displayed on Webpages of NS Panel Pro - are not working.
They are being there, you can see them, you can click them. NS Panel Pro will confirm success.
But nothing is happening on iHost itself. Zero reaction on turning scenes via NS Panel Pro.
But - there is one more thing - the same link to iHost Cast opened on NS Panel Pro:
Scenes not working - zero reaction on iHost
But if next to scene I have tile of device that scene include and will click on that device - I can turn it on and off and have reaction on that device.
So… cast is being displayed properly on NS Panel Pro. I can click on any scenes from iHost - will get confirmation from NS Panel Pro - Success - but nothing is happening on iHost or with device - scenes are not turned on on iHost
But I can turn on or off devices via iHost Cast on NS Panel Pro.
So there is communication between NS Panel Pro and iHost Cast - but works only for devices not for scenes.
Hope this time I was more clear.
Get it, no problem. We will try to fix it in v4.0.7 which will be released in 2~3 days.
Thank you very much.
There is one positive thing with recent major update.
I think that NS Panel Pro is now displaying temperature and humidity data more in real time.
It was known issue to NS Panel Pro software developers. Earlier it was helping to turn on eWeLink app on android phone and then NS Panel Pro temp and humid data were updated.
Now I think it is improved without any extra tasks on the phone.
If you could please confirm that this problem was solved in latest firmware?
Would you please tell me which T&H device you are talking about? SNZB-02P? SNZB-02D? SONOFF TH Origin? SONOFF TH Elite?
I like to test this too
Can you please add my device too?
ID = 100250c266
THank you very much.
Thank you very much for your interest in NSPanel Pro v4.0.x firmware.
The firmware has been deployed for your device. Please navigate to Settings -> About to check the update. Please let us know if you met any issue.
Hi, please add V4.0 for device ID 1001e0c3d0 thanks
Hi, I would like to join too
I would say for all Zigbee and WiFi devices.
As explained - the problem is known to NSPanel Pro developers. That in the past it was taking long time before NSPanel Pro was able get data from sensors. Opening eWeLink app on the phone was helping a lot - opening app = refreshing data on NSPanel Pro. Some keep running app on the phone so the NSPanel Pro was always displaying actual and latest data.
Now - I use SNZB-02P - many of them, and Sonoff TH Elite - few of them. I noticed that values of temp and humid are changing more often - following the real values changes on sensors.
But it is just my initial observation as I was keeping focus on mentioned earlier 2 problems.
I will keep eye on that… if will know for 100% that data flow was improved - I will let you know.
Sadly the NS Panel Pro 120 doesn’t seem.to.display correct temperature values. In fact mine do not display any temperature readings at all.
@sliftspb @Joskiee Hi, the firmware has been deployed for your devices. Please navigate to Settings -> About to check the update. Please let us know if you met any issue.
Sorry about the issue. To better assist, could you confirm the following:
1.Are the devices you added for synchronization not displaying data on the NSPanel Pro?
2.Or is the current weather temperature not showing?
3.What is your NSPanel Pro version? Please check if there’s a new update available in the settings. If this issue occurred after an update, kindly submit logs via Settings > About. We will work on it ASAP. Thank you!
I hope this question is directed to me.
Mine displays temperatures on the hardware as they should.The problem.is more on the ZHA side. I guess that has got to do with the Sonoff integration (which is not supported by Sonoff)
The Pro displays temperature readings, the Pro 120 does not expose any sensors.
Even in the case of the Pro, it will suffice if users are able to calibrate all temperature readings through the ewelink.app, at least.
In additional why can’t they be used a for alarm activation if sensors have not been added? That restriction denies the NsPanel to be used as an.alarm control .panel.to control and synch other devices through ZHA. Free the NsPanel, throw uts shackles so that it can shine in the open world beyond the Sonoff ecosystem.
Też poproszę. ID 1001ea2675
I have an NSPanel PRO that until recently worked acceptably. After the last update, when the software versions reached the versions below:
APP version: 4.0.6
OS version: 4.0.0
Cube version: 1.13.0
for me the way NSPanel PRO works became extremely annoying.
Before the last update, notifications were displayed on the display when they appeared and the display was deactivated, depending on the set time.
Now if a notification appears, it activates the display which becomes active and remains active until I touch the button under the notification.
At night it is extremely annoying and especially totally useless but also extremely frustrating to wake up to the NSPANel display being active and remaining active until it is manually deactivated!
Why is there no possibility to choose if I want the notification to activate the display. Logical and normal would be that this facility would exist when setting the scenes. But for now, it would be extremely useful if we could revert to the previous version when the notification was displayed and after 15-30 seconds, depending on the active display setting, the display would be deactivated but the notification would remain and could be viewed when the display was activated!
Hello, thank you for your feedback, and I apologize for the inconvenience. I completely agree that the screen should return to its previous timeout setting after a security alarm is triggered. Our development team has addressed this issue in an upcoming update, which is scheduled for release by next week. We appreciate your patience.
Understood. I just ran a test and encountered the same issue: after syncing with HA via SonoffLAN, the NSPanel 86 gains capabilities like security alarms and temperature monitoring, but the NSPanel 120 does not. It seems this add-on does not yet support the NSPanel 120 device (note that the add-on is not developed by our team). However, I can share a preview we (iHost Open Source Project) will take over this CoolKit-Technologies/ha-addon in order to add new features and new devices support. Home Assistant users can expect significantly improved eWeLink device support in the coming months.
Hi, please add my device to the Test group (nspanel pro 120)
Device ID= 1002609996
