New update for NS Panel Pro with the ability to pair external temperature sensor for TRVZB… maybe?
Testing with different TRVZB and different sensors does not pair the sensors with NS Panel Pro even if it sees them. While with ZBBridge-U it works. (TRZVB release 1.2.1 NS Panel Pro 3.7.0 ZBBridge Ultra 1.6.0 SNZB-02P 2.1.0 )
@ward Am I doing something wrong? Do I have to do some different procedure to get them to pair?
Hey
Are the TRV and 02P on the same gateway?
Yes in same gateway.
But…I have partially solved it. A restart of the NSPanel Pro is not enough, but you have to remove the power, wait a minute and then reconnect the power.
Now a stability problem has arisen
…the sensors continuously decouple from the reference TRVZB and continuously reconnect. Consider that the WiFi Router, tenperatur sensors, TRVZB and NSPanel Pro are in the same room, 3/4 meters apart, without obstacles. What do you say?
Stability… guys… stability.
If I have to go and do these gadgets in a house, allow me that one does not have to be a nuclear engineer to be able to install them and every time do laboratory tests.
These must be put on the market working and correspond to what Sonoff and iTead write.
Allow me to write this as a user, because then you will lose patience and a result from the sales market will come back to you like a boomerang.
I’m sorry because I believe in it…
Bonjour
J’ai mon nspanel86pw qui ne propose pas de nouvelle mise à jour alors qu’il est en 3.1.0 et il vient de sortir la 3.7.0
Comment faire ?
please set a timeout for it, 15s would be good. Wait for the screen to dim out and then wake it up. These steps force a fetch of new updates in additional to daily checks.
It doesn’t have to be the distance issue. Zigbee and Wi-Fi also have interference when channels overlap.
Do you mind submitting feedback on both the NSPanel Pro and App so our support team can further help you with this?
Thx in advance
What feedback do you want to have? Try to be clearer and I’ll help you…OPS…we help each other ![]()
Hey
It’s just a button in the settings page, which will send the devices and app logs to the support team.
You can find it both on eWeLink App and NSPanel Pro side.
Cela ne fait rien j’ai essayé de le redémarrer… depuis 3 jours et rien
OK I know. It will be done!
At the moment I test the wifi and zigbee network and try to improve where possible, but allow me, that this “effect” of disconnecting the sensor is only on a group of TRZVB and does not do it on the neighboring one. I will also try to replace the sensor with another… but I and everyone expect MORE STABILITY on all Sonoff/eweLink accessories
Done
Continuous disconnections NSPanel Pro of the external temperature sensor from TRVZB while another keeps it associated and random happens on other TRVZB. SYSTEM INSTABILITY. Analyzed wifi and ZigBee network no interference. Devices all updated to the latest releases. All close to each other and for no reason connect and I bet the external temperature sensor. Which with Gateway Ultra does not happen.
In photos same temperature sensor in 2 TRVZB with two totally different temperature values…
@ward …I sent feedback but there is no word here about the stability of the new releases
Thx for clearing the possibilities and providing more information.
I’m turning this post into a support ticket with all the information included. If you have submitted feedback from the NSPro and eWeLink app, they should merge under the same email.
