Only NSPanel and ZBbridge This Works?
Hallo Forum.
I am new in this Forum and my first Question.
Is ist possible to monitor Tem/Humid Sensors, that are paired to ZBbridge, on the NSPanel pro.
Or do I need a IHost?
Best Regards
Volker
No need. Pretty sure the NS Panel Pro has built in Zigbee. The NS Panel non-pro had built in temperature but its accuracy was poor.
Hello.
Thank you for your reply.
I think I should give more details.
I have seven temperature humidity sensors in the basement, which are paired with the Zigbee Bridge via Zigbee.
Upstairs I have four other sensors that are paired with the NS panel via Zigbee.
All sensors are displayed in the Ewelink app.
Unfortunately, I can’t put the sensors of the basement on a devicesite of the NSPanel
Thank you.
Volker
On NSPanel Pro, slide your fingers from the top of the screen to the bottom, then a Menu will appear.
Click on “Add device”.
But in 8 months using this device, I always have problem with the temp/humid sensors SNZB-02 becoming offline on NSPanel Pro.
The temp/humid stuck on the same level and you need to pair it again, almost every month.
I added many others BASICZBR3 to try to increase the zibgee signal strengh, as they are supossed to work as a signal extender, but I’m pretty sure they don’t work as announced…
Cause off the Signal strength I paired the Sensors from the ground-floor to the bridge. To bring them upstairs via Network.
The NSPanel pro is upstairs
