hi. what type of ZigBee fire sensor works with ns panel pro
Hi, fire/smoke/CO detector is for your safety.
I have many issues with Temp/Humidity sensors becoming offline on NSPanel Pro, so I would suggest you buy something independent from NSPanel Pro.
Regarding NSPanel Pro, which unfortunately does not include the ZigBee fire sensor, I am interested in:
Which device can I configure as a thermostat in NS Panel Pro?
Specifically, I’m interested in whether I can use Sonoff SNZB-2P in combination with MiniR4 or ZBMini L2?
I can add the SNZB-2P to NSPanel Pro without any problems, however when I select the “Thermostat” tab, I can’t add the MiniR4.
