🎁 Join the NSPanel Pro New Feature Experience Survey Now, Share Your Insights, and Win Zigbee Sensor!
I believe you were talking about Home Assistant integration through MQTT Discovery protocol, right? Which requires you specify information for MQTT Broker through eWeLink App -> NSPanel Pro -> Device Settings -> Home Assistant -> Sync Zigbee Sub-devices to Home Assistant.
Got it. We’ll work on it.
That’s a shame! I get that R5 and S‑Mate don’t sell as well as Zigbee devices, but that doesn’t mean the product line has no value. eWeLink‑Remote fills a completely different niche - ultra‑low‑latency local control without needing a Zigbee coordinator. Many users rely on it specifically because it solves problems Zigbee can’t.
Thread can do direct binding, but it’s still a full network stack - heavier, slower and far more power‑hungry. eWeLink Remote is a tiny BLE trigger with instant response and multi‑year battery life. Completely different class of device.
So I hope SONOFF reconsiders. Even a small update or a next‑gen version would keep the ecosystem alive and give existing users a clear upgrade path.
I would say 95% experiments. I have it in my workshop so can turn on some stuff with it like my bench power supply or soldering iron, which appear on host anyway, but it means it is right next to where I do soldering. I would be fine with installing dockers as I have some experience with running portainer on Home assistant already. I don’t think it was the usual Portainer there: I can’t remember where I got it. GitHub somewhere. I would however like to know how to add the NSPP server to Node Red on the NSPP as it is pretty much the last thing I have to do in order to write my guide in how to set this up.
No, I think it is this one (ref. Image, that has exposed my devices to the HA Matter integration.
Brilliant!
My experience with panels and Sonof panels (NS86pro and both NS Panels). I also own 2 panels of another vendor. When I compare these 2 brands, it is clear to me that Sonoff takes a step further and delivers more value for money. When I look online in several communities, it all comes down to a high performing panel (like the NS86pro) and a tablet size 10+ inch panel. Powered by a wall socket. What really everyone asks for and looks is a good native performing Home Assistant integration including video. I do understand dat Sonoff makes lots of devices, however this can make a difference as using the 4.2/4.3x beta it is not stable enough. The 4.xx beta crashes inside the companion app, yes not a fault of Sonoff maybe, but why does it work on an android tablet?
My experience is that it is still buggy, better than the other panels I own, (XL and the normal sized shelly). I think Sonoff should consider a native panel 100% pure focussed on home assistant with extra cpu and memory power behind it. All my sonoff devices are in Home assistant, so why try to bridge them when you can run native Home Assistant?
Thank you sonoff for adding more functionality, but consider a panel without a huge OS with all whistles and bells but a pure web or native app for Home Assistant. And yes I agree with the previous posts that MQTT fails and many of the same issues I experience.
To be fair with the Bridge on NSPanel. It is useful.forSonoff devices that were not exposing their entities in HA.
With Bridging those devices are now part of the HA ecosystem.
I personally l8ve the fact that most of my Sonoff devices appear in HA as matter devices
Thank you so much for sharing such a detailed and insightful review! We’re thrilled to hear the NSPanel Pro is serving as your go-to smart home control center, and that local control & Zigbee integration are working so smoothly for your household.
Regarding your feature requests:
  1. Conditional Scenes Based on Sensor Values – This functionality is already supported in the eWeLink app. You can set a scene with a time window and configure it to trigger other devices when a sensor meets specific conditions during that period. Please give it a try, and feel free to reach out if you have any questions.
  2. Free Drag-and-Drop Button Layout – We need to evaluate whether this would be a practical experience on the smaller screen, so we’ll take this into consideration for future updates.
  3. Custom Icon Upload & Expanded Grouping – We’ve added the ability to upload custom icons to our upcoming feature roadmap. However, we’d appreciate a concrete example of what you mean by “expanded grouping for large installations” to ensure we fully understand your needs.
  4. Energy Dashboard – Currently, the panel only displays the top 5 devices by power consumption. Are you looking to view the energy usage of all your devices directly on the screen?
We look forward to your reply! :blush:
We’re glad you’re enjoying the device, and we can’t wait to keep refining the experience based on input from users like you!
You could add an “energy” node to your eWeLink Cube Node Red palette. This could allow devices with power measurement (such as the path series) or switches with presumptive power outputs (for example I have basics connected to panel heaters of an advertised wattage). Then as Node Red allows a display you could log into whatever device was running it and view it.
Then the small Screen of the NSPP, limiting it to 5 devices, would be irrelevant as it’d be displayed elsewhere.
Would you like me to summarise how installed node Red? Most of the effort has been about starting scripts so it works on reboot (that I’m thinking of removing anyway) and writing a non-expert understandable text. I could tell you in a few seconds. Just help me connect to an NSPP locally so I can finish my guide and I can easily then help with the docker stuff.
I truly love how easy it is to setup Home Assistant (companion app) in version 4 without rooting it. The integration gets better and better. I now have a NSPanel Pro 120 in every room. I’m using the panel as a zigbee router.
【Winner Announcement】NSPanel Pro v4.x.0 New Feature Sharing Event – Thank You for Your Enthusiasm!
We are thrilled to announce that three participants @jam3 @alyusuph @Derex stood out with their unique insights and outstanding contributions during our NSPanel Pro v4.x.0 New Feature Sharing Event. Congratulations! You will receive a special gift from us. Please check your private messages and provide the necessary details so we can arrange the shipment as soon as possible.
We would also like to extend our sincere gratitude to every participant who shared valuable feedback and ideas. Your passion and creativity are helping shape a brighter future for NSPanel Pro. As a token of our appreciation, all participants will receive an exclusive discount code valid for any product on the SONOFF official website. The code will be sent to your private message inbox shortly—just enter it at checkout to enjoy your discount.
We look forward to seeing you again in future events. Together, we build a smarter world!
Thanks for the coupon but it doesn’t help me much. If I save money it’s cheaper to buy sonoff products in my country.
