I’m just starting to try to get eWeLink Smart Home integration to work within my Home Assistant. I’ve gone through what steps I can find to install it, which it is installed but it shows all my devices (which all I have right now are just Sonoff outlet smart plugs) are not supported.
One step that confuses me is the Long-Lived Access Token. I’ve got that token copied off, but on the eWeLink Smart Home Integration, there is no Options entry to put in the auth code. The screen shows the Network web interface setup but no Options area. I don’t know if that’s why it’s showing my devices as not supported.
I do have the Sonoff-Lan installed and it shows the devices on it, and my main dashboard does show them on that also. But it’s just the eWeLink Smart Home screen I can’t get to work.
Can any give me any help or possibly let me know what I’m doing wrong?
I accidently said Integration, but I did do it through the Add-Ons. When I’ve tried that link with the git URL listed in it, I get the following error:
I had found one other link that used a slightly different URL as: GitHub - CoolKit-Technologies/ha-addon
This one would work and I was able to add this to my Home Assistant but I get the following when I open my Home Assistant Smart Home:
The message is clear that the S40 Smart Plugs are not currently supported. I believe it is on the list of items eWeLink will be adding in the future releases of the Add-on. I would check the end of every month to see if any new updates have been posted.
I can tell you that the S31 Smart Plugs do work with the current Add-on version. I have 8 up and running.
Thank you. I had a friend that had been using Home Assistant for awhile and he had his working fine, but after you said that, I re-asked him what models he had and he said they were the S31TPB plugs. And he had just received the same ones I got and had the same issue. So that explains that issues.
