I figured it out! I remembered that the one that worked was the first I bought, months ago. Then I remembered that Zigbee2CUBE didn’t always exist for iHost. As soon as I turned Zigbee2CUBE off and deleted the uncontrollable bulbs (they flashed to acknowledge being disconnected), did the 6 long off short on reset for the TRADFRI bulbs so they started soft pulsing. Then boom, they pair with full control! Strangely the firmware is still reporting as 0.2. Not too worried about that if they work though. ![]()
For anyone coming along behind. I had an issue where IKEA Tradfri LED1924G9 was pairing with iHost, but wouldn’t allow me to control the colour of the bulb. Turning off Zigbee2CUBE and re-pairing added the colour control back! IKEA model number was 505.176.37
Please check this topic:
@genome-splicer thanks for the tip.
I have had 2 IKEA Tradfri bulbs for a while now that I had paired but couldn’t control with Ihost.
I tried disabling Zigbee2CUBE in the pilot features and repairing both bulbs.
I can now fully control both bulbs directly through the Sonoff Ihost UI and using Node-RED.
The bulbs are
- 605.456.73 - LED2201G8 - IKEA Tradfri LED 1055 lm
- 305.474.71 - LED2109G6 - IKEA Tradfri LED 806 lm
Thanks for the suggestion. I had seen that post in my search, but it didn’t help in this case.
My next challenge is getting the IKEA TRETAKT mains switch to work (805.565.14). It only pairs when Zigbee2CUBE is turned on. But it doesn’t show any controls, even in the scene builder as suggested in the topic linked.
I’m assuming this UK version is the same internals as the EU one here:
As far as I know, it’s not supported yet.
IKEA plugs generally have the same module across regions, at least for TRADFRI. If Z2M merges these versions, my assumption would be right.
Close this discussion due to the official release of iHost CUBE V2.3.0 with Zigbee2CUBE Exits Beta.
