👨‍💻‍【Release Note】eWeLink CUBE V2.6.0 Update
V2.6.0 [2025.08.07]
iHost V2.6.0 Now Officially Released!
This version, V2.6.0, brings broader device support and significant improvements to both the eWeLink Smart Home Add-on and Matter Bridge.
Please take a moment to read through the notes before upgrading your device.
New Feature:
  • Added support for UREAL’s central air-conditioning controller, with automatic syncing of its connected indoor air conditioning units to iHost.
Optimizations:
  • Reportable changes and reporting intervals configurations are available for sensors, including:
    • SONOFF SNZB-01P
    • SONOFF SNZB-02P
    • SONOFF SNZB-02LD
    • SONOFF SNZB-02WD
  • Using “No occupancy detected for a duration” as scene triggers is available for sensors:
    • SNZB-03
    • SNZB-03P
    • SNZB-06P
  • eWeLink Smart Home Add-on Improvements:
    • Now supports logging in with the same eWeLink account across multiple iHosts.
    • Now syncs firmware versions of connected devices.
  • Matter Bridge Enhancements:
    • Added support for Water Leak Detectors.
    • Now you can copy the Matter Setup code with one click.
:frowning:
Add a relay disconnection function for the SONOFF ZBM5-3C-86 device.
The ZBM5-120 version already supports this.
Will the ewelink smart home add-on support the MINI-RBS device?
@KwayLi99 I installed version 2.6.0. The optimizations listed don’t work.
Optimizations:
    • SNZB-03
    • SNZB-03P
    • SNZB-06P
Can you shed more light on the UREAL Control Hub. I tried looking it up on the web with no success. This functionality is interesting to me.
You need to ensure that the subdevices are updated to the latest version and clear your browser cache for this feature to appear. However, we have currently discovered that this term has not been translated, so it may still display in Chinese. We are working on an urgent fix for this issue.
Thank you for your understanding.
We will be making this product info, and relevant information will be announced soon.
I added the SNZB-06P device back to ihost. Now this condition is available. As you wrote, it’s in Chinese. But the old SNZB-03 motion sensors don’t have this feature.
Can you add relay disconnect function for ZBM5-3C-80/86 device
Nice to see my Tuya buttons and also water detector now come across in Matter into Smartthings. :ok_hand:
The only device type, for me, still not showing is the smoke sensor. Is this on the road map?
In the latest update, it is not possible to save a script. When you click the SAVE button, nothing happens and the script is not saved.
It is also not possible to turn on or off a script in the script list.
upd:
I found a temporary solution to the problem until the developers fix the bug. In any existing scenario, you need to activate the push notification slider (turn it on and off). After these actions, this scenario will be saved as before. This action must be performed with each scenario separately.
After switching the slider for push notifications, the slider for enabling and disabling scripts will also start working.
Activated push notifications for the motion sensor. I opened the CAST page, and there are no motion notifications or browser notification requests. I checked it in the chrome browser on windows and android. I also noticed that before the ihost update to 2.6.1, it was possible to see the sensor status change in real time on the CAST page, but after the update to 2.6.1, the sensor status update can now be seen on the CAST page only after updating the page manually, and not in real time.
Again
Sorry fot the delay.
What kind of script are you refering here?
Please upload your system log in the feedback or DM to me.
We’ll pinpoint the problem ASAP.
The notification only works in remote CAST page, not local.
Are the remote page still missing?
If so, Please upload your system log in the feedback or DM to me.
Can you specify the function?
