Does iHost support energy monitoring for any Zigbee plug available in the market?
Hello everyone! Anyone know if this zigbee device works?
ZigBee 2200W 10A - NOUS L6Z
Many thanks.
When can we expect the new update?
Why do you ask? After all, you know the answer. In the future, of course.
⊠with the âbig updateâ thingy?
Any idea if is it possible to add the feature Do not disturb, in other words, the Power on Behavior, from Tuya lamps, into iHost?
I think the cluster is 0300 or EF00. Identify is 0xFA with the 00 to off and 01 to on.
Still asking if itâs possible to add support for Moes Thermostat. Itâs recognized as TSO610 and manufacturer is _TZE204_aoclfnxz.
Zigbee2MQTT supports current model, found this discussion if it helps.
Thx for the info, we will note this down and see what we can do when we expand device support.
Is the existing spreadsheet still being updated with supported device models?
Just pinged the CUBE team, there will be an updated version soon.
I have a human presence sensor from Tuya:
Model ZG-205Z
I can add it to the iHost and that it. Not presence triggers actions.
I have tried to add a couple of the IKEA TrÄdfri 1055lm lights model number LED2201G8
They are supported in Zigbee2mqtt. They pair with iHost, but no controls appear. Are they in the pipeline? Thanks
You donât need to pair IKEA bulbs with iHost via Zigbee2MQTT. These bulbs can be connected to iHost as Zigbee 3.0 devices. They work flawlessly and all parameters can be controlled.
Sorry, I didnât explain myself properly. I have three of the LED2201G8 bulbs. The one reporting (in iHost) firmware version 0.2 works fine, with full control. The two reporting version 2.4.5 will pair with iHost, but show no controls. Iâm not using Zigbee2MQTT. I was only linking to the info card for the benefit of any developers.
I have looked through the available IKEA firmware repositories and nowhere do I see version 2.4.5. The latest for TRĂ
DFRI white spectrum bulb E27 (ID: LED2201) is 3.0.22. Something is wrong with the version reporting in your instances. Try updating the firmware, as this working bulb probably has the current version.
At HA, older firmware versions from IKEA didnât behave correctly either, so this could be a clue.
Thanks for looking into this. I had also noticed that the 2.4.5 version number only matches the IKEA JETSTRĂM light.
My problem is that I canât update the bulb firmware via iHost as it tells it is the latest version. Is there some way to manually force an update via iHost?
As a backup, Iâve ordered a Zigbee dongle so I can try and update the bulbs via Zigbee2MQTT.
I donât know any way. In ZHA itâs possible and it works as expected.
This may be the only way to do it.
