Logs received also, the engineer are checking on that.
Get back to you later.
Hi. From your sys logs, MatterBridge actually had not init. Pls check this issue that can resolve your problem.
@hiconkong and @yitie,
I have tested seeking this step-by-step and the matter is working again.
I think the devices control time and responses are slower than before.
Thanks for the support.
No worries, glad to hear that.
As you may know that the Matter is still in its early stage, and the giant companies like Apple, Google, Amazon etc. slight tune the feature on there own platforms with quite a frequent pace, and not aware the developers, it’s really frustrated.
Sometimes it’s our bugs, but most of them recently are caused buy the changes of the giants, the only thing we can do is keep on the tracks and hoping the Matter bacame more stable in the near future.
Hi, Have the dev team made any progress on this?
It is not compatible
Can you recommend me a good one that is compatible?
Hi. I have some Aqara / Lumi temperature and humidity sensors which show up as temperature / humidity sensors in iHost but there are no readings displayed. Please could you help?
Also - feature suggestion. When a device is deleted can we not also delete the scene associated with it as I often want to reuse it / have only deleted the device because it’s become disconnected. Cheers!
Temperature/humidity reading issues we will fix in the next release
When is this going to happen?
Hey I think the whole device type is not supported yet, not just the Aqara one
I’ve tested the RTCGQ11LM on eWeLink CUBE Version 1.13.4 and its working again. Now is showing the Battery percentage, but the Luminosity is still missing. Even though it’s old, it’s still the best motion sensor I’ve tested.
I tried to pair the Xiaomi Mijia WXKG01LM button to the iHost, but it hasn’t been recognized.
Xiaomi devices are notorious for not following Zigbee standards.
Is it possible to add suppor for MOES Smart Thermostat ZHT-002?
Devices are paired as a router without Zigbee2CUBE but failed to control. With Zigbee2CUBE they appear as “Not supported yet” -devices.
