ok, I hope the problem will be solved.
good luck.
good luck.
What about the SNZB-2P?!?
Why is there no Paral Sync update? I think the last update was a little more than two months ago! I believe that by updating it, a considerable number of existing problems have been eliminated (support for TVR, SNZB-2P…).
did you solve the problem ?
This app sur synchronizing device from NSpanel pro to iHost,
this is great BUT what can be greater is the other way :
Sync iHost devices to NSpanel pro.
In my case I think i could besoin very handy to be able to use device/scene/security from iHost
NSPanel pro can be a the perfect remote for iHost.
I known that I can use cast ans NSpanel pro web page, but this is far from being optimum
Why does the NSPanelPro access token in Paral-sync expire?
you have to obtain it again.
I have 1x iHost and 2x NSPanel Pro
I want to connect both my NSPanels Pro to my iHost
But for today I can do only one !!!
Why ???
We need backup option for iHost ASAP !!!
I do print screens to make backup of my scenes !!!
Sonoff this is a joke to use this as backup in XXI century !!!
Why? Because no one at eWeLink has come up with the idea that some weirdos would buy more than one NSPanel Pro and want to use them all at the same time ![]()
Why do you ask questions like that? ![]()
Innovative backup method indeed! You can also draw ![]()
It sounds like a bad joke, but there’s nothing funny about it. The topic of iHost backups has been discussed with eWeLink since the day the device was released. In this respect and several others they are unreformable.
Sonoff should be forced to place huge warning on iHost box.
This is dangerous stuff… no backup allowed… using at own risk!
Hola yo tambien estoy en ese mismo caso tengo dos NS Panel Pro y solo puedo sincronizar uno a habido algun avanze en respecto a eso ?
La solucion estaria en poner uno en modo HUB y otro en modo Router ?
Alguien puede decir algo mas ?
Hello.
Is there any information when two-way synchronization will be possible? NSpanel Pro > iHost, iHost > NSPanel Pro?
And when will TRV be supported in synchronization?
Use Matter Bridge to port iHost devices to NSPanel Pro. And the Paral-sync addon to import NSPanel Pro devices to iHost.
No such plans at the moment.
Hi Ward!
Can you elaborate more on the two way sync using a matter bridge? I tried my self but couldn´t make it happen. I´m using a iHost (coordinator) + NSpanel pro (router mode), also I´m using a echo as a matter bridge to present zigbee devices to alexa.
Thank you very much for the support!
Thank you for the design ![]()
so the approach is to build to 2 zigbee networks and present the items the iHost.
If for example, the NSpro is the main entrance of the house it´s not the perfect solution if I want to turn all the lights (arriving at night). The final solution is tha bi-directional communication of both iHost and NS Pro.
Your example works great if for example I want to have in each room of the house a NS pro and the iHost as the main orchestrator of each network.
can the NSPP act as the matter controller instead of the Echo?
without bidirectional paral Sync I guess you are limited to matter device types? Are all your Zigbee devices a matter device?
No, they’re not. Zigbee devices are not Matter device at any point.
