Teki
June 9, 2023, 7:47am
1
Paral-Sync add-on allows you to control the local Zigbee device of NSPanel Pro in eWeLink CUBE.
Step 1: Add and install the add-on
Add and install
Search for Paral-Sync add-on and add it to your add-on list, install it.
Step 2 : Run the add-on
Run the Paral-Sync add-on
Volume: any volume /workspace/data
Step 3 : Open the webUI
Open a new browser tab and go to ihost ip:8322
example: 192.168.1.110:8322
Click Get access token and go back to iHost page to confirm.
Click Next
The add-on will automatically search your NSPanel Pro, click Get access token
Follow the Guide to operate your NSPanel Pro
Click Done and on the next page you can click Sync to sync the devices to CUBE.
Note: In next update of this add-on, you won’t need to open a new browser tab, the webUI will show on the add-on page directly.
Will this void the waranty
Teki
June 12, 2023, 2:10am
3
It won’t, this is developed by eWeLink. it just sync your NSP devices to iHost
volume cannot be specified during paral-sync installation. change is locked
Why can’t I synchronize SNZB-2P?
sensor snzb-02d is not displayed either
Teki
July 15, 2023, 9:25am
7
For developers
This add-on is open on Github, if you’d like to know how it works, check on github:
when will the snzb-02D temperature sensor work in parallel-sync
Alexie
September 7, 2023, 7:18am
10
Next weekend… The updated addon will support 02D and 02P. Remember to upgrade NSPanel Pro’s firmware to 2.0 first - it’s also expected to be released next week
thank you for the information
Still no support for SNZB-2P!
ociepa.ekotox:
paral-sync
We will update the paral-sync addon to support 02P and 02D.
Hi, is there anyway to sync two nspanel pros to the ihost? I can only do one and then the other is greyed out.
Witam wszystkich. Dlaczego dodatek paral-sync synchronizuje urządzenia ZigBee NSPanel Pro->IHost, ale odwrotnie czyli IHost->NSPanel Pro już nie? Teraz trzeba wszystko usunąć łącznie ze scenami z IHost i przypisać do NSPanel Pro aby były widoczne w aplikacji i otrzymać powiadomienie o stanie urządzenia !
Daniel_Zhan:
support 02P and 02D
We are waiting for support for 02P and 02D and we expect support for Sonoff TVR as well!
Maybe I did something wrong but the NSP (no pro) entered IHost like simple buttons gracias
The SNZB-02D sensor added to nspanel pro is not recognized by ihost. When will this problem be resolved?
Teki
November 20, 2023, 9:24am
22
hi
there will be a new version released to support SNZB-02D this week, if everything goes well.
