Hi, I have iHost and two NSPanel PROs. First was added through Paral-sync without issues but the second one has “Get access token” grayed out, image below. Does iHost/Paral-sync support multiple NSPanel PROs ?
hi, sorry to tell you that currently the add-on supports only one NSPanel Pro, it will support more in the future, may take some time.
Hi, I switched my second NSPanel PRO to router mode and bound it to the first NSPanel PRO in hub/gateway mode, adding new end-devices to the gateway when near router does work but when both are moved away it’s not - both NSPanels are using the same wifi network. Does that mean that router is a repeater only when there is reachable Zigbee signal? Why not use wifi, LAN mode?
