ZBMINIR2 firmware update fails
Hi ward!
Not! I deleted the device from the app and paired it again, but it still doesn’t recognize the new firmware available.
Could you please also submit a ticket from the app, so we can further look into this issue.
Many thx
@jam3 @fabrizio Could you try logging out of the app and logging in again?
This may fix a potential issue.
No need! After few minutes from re-pairing the new firmware came up!
Thank you!
For the past ten days, I have had a joyful and cultured exchange of information with Sonoff. As a response to my Support ticket placed, I received some assurances and instructions, but nothing more came of it. The firmware update has disappeared as if it had never been available. To this day, it has not returned. This doesn’t particularly worry me, as my ZBMINIR2 works fine. Nevertheless, there was some purpose of producing a newer version after all. Maybe I’ll find out what happens next, as I’ve been waiting since Friday for the next portion of so-called technical support :next_track_button: :laughing:
It could have been affected by the same situation as TRVZB.
Are Sonoff guys aware of this? Do you know about any steps to correct the problem? I’m asking because after the initial reaction to the ticket placed there is silence, and it doesn’t sound good. Not good at all.
They should be aware of this since you’ve placed a ticket. What’s the last response from them?
I just got the ZBMINIR2 device. I added it to nspanel pro. Right after adding it, the eWeLink app shows updates.
After adding ZBMINIR2 to IHOST, the update is not reported.
The latest is Please try upgrading again once the new version becomes available in the App. The point is it is not becoming anything :slight_smile:
Here is today’s response from Erin:
Sorry for the delay. The new firmware is still being deployed and may take one to two weeks to be fully released. Thank you for your patience.
It must be quite a challenge :slight_smile:
I see, thanks for the update :slightly_smiling_face:
The update is that time passes and nothing happens. With this attitude nothing like almost perfect Pekin Daxing airport would ever happen in your country. I can only guess that the breathtakingly precise baggage circulation system does not use any Sonoff hardware :no_good_man:
@ward @Daniel_Zhan
When will the OTA update (1.0.2) for ZBMINIR2 appear in ihost?
Try mannually checking the update
I’ve checked several times.
I can’t find the new version.
Let me quick-check with the team, I just realized I am using a debug version.
Could you please try to power cycle the device? If you still can not see the update, please send us logs for a look.
Many thx!
