ZBDongle-E router not detected by Bridge Pro
Not sure if this is an eWeLink issue, a Sonoff hardware/firmware issue, or simply a misunderstanding on my part but I can’t get my Sonoff ZBDongle-E, flashed in router mode, to pair with my Zigbee Bridge Pro (ZBBridge-P), even though everything appears up to date:
  • Dongle flashed with the latest Router firmware (v8.0.2)
  • Bridge Pro on latest firmware v3.3.0
  • eWeLink Android app on latest version v5.26.0
  • Wifi on 2,4GHz
  • According to the Bridge Pro firmware changelog, router-mode dongle recognition should be supported since v2.3.0: 【Zigbee Bridge Pro】Firmware Changelog
Despite this, the dongle is never detected when trying to add it as a sub-device from the bridge’s “Add Device” button in the eWeLink app.
Has anyone gotten this combination working? Any known compatibility issue or specific pairing steps I might be missing?
Thanks!
If I remember a nearly identical case from the past correctly, the situation looks like this: even though the Bridge Pro firmware changelog claims it supports “router‑mode dongle recognition”, that support only applies to Sonoff dongles that implement a full Zigbee router profile (Dongle‑P, Dongle‑M, R5). The ZBDongle‑E uses a minimal router firmware with no fingerprint, no Identify cluster, and no Basic cluster, so the Bridge Pro cannot detect it or pair with it. This isn’t a user mistake or a dongle malfunction — the Bridge Pro simply isn’t compatible with the Dongle‑E in router mode, and there’s no workaround to make it pair.
It sucks, I know :slight_smile:
Thank you for your response. Just for information, I flashed the router with an older version (via the online tool sonoff-dongle-flasher): the dongle was properly recognized as a router with version 6.10.3.
However, this firmware version seems a bit old and I won’t use it. Instead, I’ll prefer purchasing a mains-powered device (a ZBMINIR2) to play the role of the missing router (I’m a beginner and I discovered the limit of 10 end devices).
It’s a very good idea! Remember not to utilize the Turbo mode option. It is not as good and promising as it seems to be.
