Sonoff Bridge pro as a router
I’m trying to get to the bottom of devices dropping out, I’ve added a couple of ZBmini’s which has helped ever so slightly but I’m still getting a couple of battery powered devices drop out. Can I flash a bridge with THIS and still connect it to my other devices in eWeLink or is it only for zha?
First glance: is that not a Zigbee Bridge and not a Zigbee Bridge Pro?
Try this:
Sonoff ZBBridge Pro Zigbee Gateway (ZBBridge-P) Configuration for Tasmota. There are two firmwares for the ZBP I can find. I assume one is coordinator and one is router, but I can’t see how to tell which is which. Do you have a spare pro? If you don’t this seems like a waste.
Router is a generic feature, but I can not guarantee it would work with all gateways. It depends on what device the router firmware emulates and the compatibility of gateways.
This might be it: had a single search on GitHub
Or I think a newer version of the firmware
Unless I had a bridge pro in a drawer I think I’d just buy a switch or an LED strip though.
I gave up on the idea and have bought other power devices.
What about a Sonoff dongle P, is the router firmware compatible with eWeLink?
If you need a compact router device powered by USB. ZBMicro would be a better option.
Dongle P, I think, has a similar chipset to Bridge P, CC2652P, if ZBBridge-P won’t work, dongle-p may not either
Ok, I’ve actually got a ZB micro arriving today because I was running out of options.
