ZBDongle-E as router does not pair to ZBBridge-U
Hello, is there a newer router/repeater/extender firmware for ZBDongle-E besides Z3RouterUSBDonlge_EZNet6.10.3_V1.0.0.gbl (that was released Jun 30, 2022)?
Or is there an alternative ZigBee router firmware for this device?
I am asking because after flashing it does not pair with ZBBridge-U.
After flashing it boots into pairing mode (green led blinking).
> appNwkJoinOrRejoinWhenPowerOn [328]:
 start nwk join EVENT,sta = 0x00
NWK Steering scan complete. Beacons heard: 1
NWK Steering State: Scan Primary Channels and use Install Code
Error: install code setup failed. Is an install code flashed onto the device?
Error: NWK Steering could not setup security: 0xB7
Examining beacon on channel 20 with panId 0x0D65
NWK Steering joining 0x0D65 on channel 20
Then it probably receives installation code(s), for few seconds green led is contant:
Update TC Link Key: New key established: 0x03
Partner: A6 A9 54 FE FF A3 65 8C
NWK Steering: Trust center link key update status: 0x03
T00000000:RX len 5, ep 01, clus 0x0000 (Basic) FC 00 seq 14 cmd 00 payload[07 00 ]
Update TC Link Key: New key established: 0x65
Then:
EMBER_NETWORK_OPENED: 180 sec
pJoin for 180 sec: 0x00
NWK Steering: Broadcasting permit join: 0x00
NWK Steering Stop.  Cleaning up.
Join network complete: 0x00
And then network is down and it starts procedure (of receiving instalation code) again:
EMBER_NETWORK_CLOSED
T00000000:RX len 5, ep 02, clus 0x0000 (Basic) FC 00 seq 10 cmd 00 payload[07 00 ]
T00000000:RX len 5, ep 02, clus 0x0000 (Basic) FC 00 seq 10 cmd 0B payload[01 00 ]
RX: ZDO, command 0x0013, status: 0x00
Device Announce: 0x2095
EMBER_NETWORK_DOWN
NWK Steering stack status 0x91
>>>> EMBER_NETWORK_DOWN
> appNwkJoinOrRejoinWhenPowerOn [291]:
 NWK attempt join EVENT, nwk_state = 0x00, appDevHadAttemptNwkJoinTimes = 0
NWK Steering: issuing scan on primary channels (mask 0x0318C800)
NWK Steering: Start: 0x00
And it keeps like that in the loop.
… or am I doing something wrong? :slight_smile:
Hey,
Thx for the feedback. Our team has been looking into this issue.
Hi, thank you. I am attaching full log, staring from flashing and then ending on endless loop of pairing with Bridge Ultra. You will find my comments it this file that {look like that}.
This log is of course for everybody that are interested in making ZBDongle-E as a router/repeater/extender paired with ZBBridge-U (Bridge Ultra).
flashing-and-pairing-log-of-dongle-e-as-router.log (48.5 KB)
I have just received and email from Aron that… does not help me.
Dear Artur,
Hi
Thanks for your email.
ZBDongle-E can be added to ZBBridge-U in the eWeLink app. Please follow these links to learn how to use ZBDongle-E.
https://sonoff.tech/product-review/how-to-use-sonoff-dongle-plus-on-home-assistant-how-to-flash-firmware/#5
https://itead.cc/product/zigbee-3-0-usb-dongle/
https://itead.cc/sonoff-zigbee-devices-work-with-home-assistant/
Please note that in celebration of our Nation Day, we'll have a holiday from Oct 1st to Oct 7th, 2024. If you have any questions about the order during this period, please send us an email. We will get back to you as soon as possible when we return to the office on Oct 8th.
Regards,
Aron in SONOFF
My understanding is: pair ZBDongle-E [flashed as a ZigBee router to extend poor ZigBee coverage] with ZBBridge-U.
Or am I misunderstood something here?
Email from Aron:
Dear Artur,
Hi
Thanks for your reply.
As you said before, ZBDongle-E can't pair with ZBBridge-U. ZBDongle-E can't be used in the eWeLink ecosystem. It can be used as a Zigbee gateway in Home Assistant, openHAB, Zigbee2MQTT, or other open-source platforms to locally control all your Zigbee devices. ZBDongle-E is pre-flashed with coordinator firmware, you can also flash router firmware to extend the network range.[ https://itead.cc/product/zigbee-3-0-usb-dongle/](https://itead.cc/product/zigbee-3-0-usb-dongle/)
Regards,
Aron in SONOFF
So… first he wrote “ZBDongle-E can be added to ZBBridge-U in the eWeLink app” and then “ZBDongle-E can’t pair with ZBBridge-U. ZBDongle-E can’t be used in the eWeLink ecosystem”.
:confused:
Hey
From what I know so far, it’s not supported for U at the moment; the product team is considering better supporting such devices.
You can alternatively use supported Zigbee lights or switches to route:
Sorry for the inconvenience.
Got response from Aron. I am pasting it here for anyone who will try to use Sonoff’s ZBDongle-E with Sonoff’s Bridge Ultra ZBBridge-U. I am pasting it here for anyone who thought that Sonoff devices works with Sonoff devices (and “Works with everything” according to the welcome message in eWeLink app).
Dear Artur,
Hi
Sorry for the type error in the first email. I accidentally typed "can" instead of "can't." I am sorry for all the inconvenience that this has caused you. The original meaning is: Now the ZBDongle-E can't be added to ZBBridge-U in the eWeLink app.
But after we checked with our technicians, in November, we will update a new firmware version for the ZBBridge-U and a new version of the eWeLink app, if you flashed the ZBDonge-E as a ZigBee router, it will support adding to the ZBBridge-U, could you kindly kindly wait for the update?
Please note our ZBDongle-E was pre-installed with the coordinator firmware and can only be used as a Zigbee gateway which can not add directly to the ZBBridge-U unless you flash it to the router firmware after November.
Regards,
Aron in SONOFF
HI, any news here. I bought ZB dongle E and loaded official router FW on it and put in on phone charger, to use it as ewelink router. I tried pairing it with bridge-u and also nspanel pro (coordinator mode) and none of them recognises dongle e as zigbee device. Please let us know if it is possible to make it work as repeater with bridge u or nspanel pro. thanks
Hello, the ZBBridge‑U supports adding a ZB Dongle‑E in Router mode.
If you’re having trouble adding the device, please check the following steps:
Verify the firmware
Make sure your Dongle‑E is flashed with the Router firmware. You can use our Dongle Flash Tool to update the firmware.
Confirm pairing mode
Press and hold the Boot button for about 8 seconds , then release it .
After releasing, the LED should start flashing green , which means the device is in pairing mode.
Once these steps are completed, please try adding the Dongle‑E to your ZBBridge‑U again.
If the issue persists, feel free to share more details or screenshots so we can help you troubleshoot further. :+1:
Hi Jemma, thanks a lot for that! I did manage to pair it to bridge-U and seems to be working now. The 8s push on boot button was info I didn’t know about- great !
I am however not shure if repeter has any improved effect on devices. I have in this area only couple of water leak senzors SONOFF SNZB-05P and temp.humidity sensors: SNZB-02D.
When i check under sensor in ewelink the quality of RSSI signal, it seems that has not improved. I am not shure if this takes more time to update the signal strenght or is there any other way of knowing if the signal strenght is improved ? thanks.
