Scenes enabled automatically not working again
What happened again? Scenes enabled by another scene were working normally, but now they are not working again. If I enable the scene manually, the scene works, if I enable it by another scene, it does not work, as if it remained turned off. Where is the problem again, it was here once, around the end of 2023.
The scenes that trigger actions involving a group—such as controlling multiple light bulbs at once—have stopped working for me.
I just created two test scenes in WEB and they worked according to the settings.
I have had the same heating scenes for several years, which turn off or on my TRV heads and scenes for turning on the boiler, turning off is OK, but after starting the scene for turning on the heating, the heads are set correctly, the control scenes for turning on the boiler are also enabled, but they do not work, they do not turn on the boiler. So I will try to edit them and save them.
It’s hard for me to assess your specific case.
Of course, it could be an issue on the eWeLink side, given that it had been working for a long time and suddenly stopped.
If they still won’t work, create a support ticket in the app.
