Dear Teki, I made another scene that fully illustrates the problem. It is very simple. A motion sensor (Zigbee) turns on the light switch (Wi-Fi), all of them are executed, but after about 5-7 seconds due to same error in the implementation (no command is executed normally 100%, the problem occurs).
I hope it’s clear and you can fix it soon.
Thanks, the problem is solved, update the iHost to V 1.10.1
I just updated to version 1.11.0, and the scenes have gone crazy, have excessive delays, and don’t even act correctly. In version 1.10 everything worked fine
Would you please submit the system log via the feedback of iHost console? We will check the issue. thx
I just can’t understand how one version is good the next is bad, how can’t you keep something witch goes right to stay right in the next version?! This issue with the scene delay was coming up so early I can’t remember!
Any solution for this behavior?
Since I bought my iHost, I’ve been facing this problem, every time that I double click, the lights start flashing and only stop when I restart the iHost.
My wife is almost killing me, everyday she asks me to change the switches to normal switches.
Using the scenes on Ewelink Cloud that behavior not happen.
What are you double clicking?
Can you describe the problem?
What does the scene you’re having trouble with look like?
Do you have the latest version of ihost v2.2?
someone found a solution for slow scenes locally, because with eWeLink CUBE Version
2.4.1, the scenes are really slow, if by mistake I click on the same switch twice the scene goes in a loop, on and off for several seconds until it stabilizes.
give details about which scene you are having trouble with? if you are building a scene using a light switch try not to use the reverse function. pressing the switch twice quickly can cause loops.
slow execution of scenes in ihost is affected by weak zigbee signal or wifi. No or small number of devices that act as zigbee routers.
I tried to upload a video,
about wifi there’s an access point in all room to avoid signal loss…don’t take care about the deal to shutdown light is about the transformer, but look the red light of T5 extreme, is not simultaneously like with app scene, at the end you can see the right light under bed remain on, when the switch near me is off, if I take a look on scenes log, it failed
Another example
And I don’t press twice rapidly, the acces point you can see it at the end of video
Is not a specifical scenes go slow, but all scene on ihost
hey,
sorry for the late reply. Do you mind downloading the logs on the settings page and sharing it with us for troubleshooting?
Thx in advance.
I have a very similar problem. There are 3 lamps in a ceiling light. If I order them sequentially: turn on the first, second, third, then until the first one turns on - the second one waits, then the second one - the third one waits for the second one. If you add them to a group and turn them on - everything works much more lively. But you can’t set a group to an event, it’s not supported yet.
if i understand correctly, i have to upload .tar file dowloaded from my ihost setting page? because is 31mb and the forum leave me to upload max 8mb, sorry but i’m very newbie on this
hey you can drop me a link of google drive or dropbox
