I can not seem to see any remote gateway devices that are paired to my minir4’s (R5 / Switch Mate Extreme) in ihost for use as triggers for scenes.
I can see the R5 / Switch Mate devices in ewelink app & web just not in the ihost.
Is this a bug or something that is on the roadmap?
Still really need to bring paired remotes into the cube as many remotes are out of range of the cube, is this ever going to happen?
You must first add the R5 and Switch Mate to the ihost.
Only then can you set the R5 / S-MATE as a trigger for scenes set in the ihost.
R5 / s-mate must be within range of the ihost.
That is the problem, the switches and remotes are spread over a 1 acre site, I can not bring them all into the range of the host
