IHOST FIRMWARE 1.11.0 eWelink Gateway
I have just upgraded to V 1.11.0 and have been desperately awaiting input from s-mate’s and R5’s into the iHost for some of my automations, It seems though that you can only pair a remote device (smate etc) directly to the iHost, this is a shame as it falls short for me as the iHost can not be installed in a location that would be in range of all of my smate / R5 devices.
Is there going to be support for eWelink remote devices that are already paired directly to gateway switches around the network
Thanks for your feedback, we have noted this requirement and it will be evaluated by the development team.
Hi Teki, I have just found another problem in my planned use, the s-mate’s can be seen in node red using the listener, but there is no output in the debug window when you operate the switch that it connects to, I know the s-mate’s are working as I have local scenes set up within the iHost using the same s-mate’s that are working fine.
hi, did you update toe ewelink-cube platte to V1.1.0?
we’ve done some test and didn’t have this issue, can you post a video? and please send the Node-red logs (on the node-red docker page - Log tab) via the feedback button on Settings page, thank you.
if you submit a feedback, please let me know the ticket ID.
