🏡【Release Note】iHost Update - eWeLink CUBE v2.14.0
:house_with_garden:【Release Note】eWeLink CUBE on iHost Version History
iHost v2.14.0 [2026/09/14]
This release expands Matter Bridge capabilities and device support, and improves eWeLink-linked device syncing, scenes, CAST, Node-RED, and overall stability. Please take a moment to read through the notes before updating to this version.
What’s New?
  1. New Device Support
  • Added support for SONOFF S61SZBTPB Zigbee smart plug.
  1. Enhanced eWeLink-linked Device Sync Support
  • The eWeLink Smart Home Add-on and built-in “Add eWeLink-linked Devices” feature now support syncing:
    • SONOFF Hydro ONE smart water valves (SWV-ZFE / SWV-ZFU)
    • SONOFF Hydro ONE Lite smart water valves (SWV-ZNE / SWV-ZNU)
    • SONOFF Hydro DUO dual-channel smart water valves (SWV-ZF2E / SWV-ZF2U)
    • SONOFF MINI Extreme Zigbee Dimmer Switch (MINI-ZBDIM)
  1. Matter Bridge Enhancements
  • Added support for syncing the following Matter/Zigbee device types to Matter-enabled platforms via Matter Bridge:
    • Pressure Sensor
    • Siren
  • Expanded Air Quality Sensor support with the following measurement capabilities:
    • Formaldehyde Concentration
    • Nitrogen Dioxide Concentration
    • Ozone Concentration
    • PM1 Concentration
    • PM10 Concentration
    • Radon Concentration
  • Expanded Boolean State Configuration cluster support for:
    • Occupancy Sensors now support sensitivity adjustment.
    • Water Leak Detectors now support enabling or disabling tamper alerts.
  • Optimized color-light mapping to ensure color adjustment works correctly after bridging to Samsung SmartThings.
  • Changed Matter Bridge mapping for multi-function devices to use multiple endpoints instead of compose, improving device compatibility.
  1. Device and Automation Enhancements
  • SONOFF BASIC-ZB1GSP now supports bi-directional energy monitoring, allowing users to view up to 12 months of energy history.
  • Scene triggers based on power consumption now support value ranges.
  • CAST now supports white and color light controls for compatible lights.
  • Expanded the following control capabilities for the Node-RED control-device node:
    • Power Percentage
    • Valve Position
    • Irrigation/Work-mode
  • Added support for viewing Tamper Alert event logs.
Bug Fixes
  1. Resolved scene execution issues when energy consumption from devices synced via eWeLink Smart Home Add-on was used as a trigger.
  2. Corrected battery status display when the reported battery level was 0%.
  3. Fixed an issue where the thermostat control page in CAST could appear blank.
  4. Fixed an issue where RTSP streams from Yoosee cameras could not be viewed on iHost.
  5. Fixed an issue where Matter Hub could repeatedly restart when removing devices added through another Matter Bridge.
  6. Fixed Docker data restoration failure for backups created in versions 2.12.0 or later.
  7. Fixed reverse-direction control issues affecting more than 10 third-party Zigbee curtain motor models, as well as calibration issues on some devices.
  8. Fixed an issue where the SONOFF SNZB-06P24 Presence Sensor reported illuminance values too frequently.
Excellent work. I would to see a thermostat there so that the iHost can control the heating.
  1. Fixed reverse-direction control issues affecting more than 10 third-party Zigbee curtain motor models, as well as calibration issues on some devices.
Waiting for this. Thanks my zigbee curtain switches works perfect. Only one model not working.
:warning: Matter bridge failure on iHost. :warning:
The bridge stops working after adding the SONOFF CAM-C44HE camera to iHost.
feedback 279474
Thank you for your valuable request. We have duly noted it. We will periodically review all feature requests as a whole, and we will keep you informed as soon as any progress is made.
Thanks for your feedback. Just to clarify – is one curtain motor device fixed, or is another one still having issues? If it’s still having issues, please send the model info so we can look into it.
Thank you for your feedback. We apologize for any inconvenience this may have caused.
We have received the log files. We will investigate the issue as soon as possible and keep you updated on any progress. We appreciate your understanding and support.
BSEED_TS0601_cover
failed to pull version v2.14.0 at docker
Hello @emre_gvn ,
To help us locate the issue more quickly, could you please provide the following information:
·iHost logs
·Device ID
Instructions on how to obtain the logs are provided in the attached guide. If the log file is too large to upload directly, we recommend uploading it to Google Drive and sharing a link that does not require access approval, as shown in the attached image.
Hi @Tamer_Salah ,
Thanks for reporting this. Could you please try pulling the image again
The instructions don’t work; I’ve already pointed that out.
thanks , i recheck now and i can pull new version correctly
Hello @ociepa.ekotox ,
We have released the 2.14.1 hotfix to fix this issue. You can now update to 2.14.1.
Hello To all
I still unable to run this or the old versions on a raspberry PI5
I already try to install the image from several ways using the:
Raspbey PI image, balenaEtche, Rufus etc, I also change the Micro SD card including the sandisk extrem and other one I also try to boot the Raspberry PI OS lite with sucess and I also try to change the Boot Options over this distro to try boot the CUBE OS without sucess
Is any one using the raspberry pi 5 with the ewelink Cube OS? Please can you please let me know how to install and use the image?
Thank you in advance for your help and support best regards
@KwayLi99
Can you please check this? Is there any way to install the cube OS on a raspberry pi 5?
thank you
Hello @MiAutomations , did you follow the instructions in the attached guide? At which step did the issue occur? If you could provide some screenshots, it would help us locate the problem more quickly.
Raspberry Pi | eWeLink CUBE
Thank you for your reply I appreciate a loot
Yes I followed the instrcutions also and I also try other ways as I mentioned all the ways without success
The ScreenShots requested is not possible once the raspberry PI 5 doesn’t boot and the Boot Light keeps Green
Can you please give me other instrctions?
Thank you in advance for your support and best regards
