šŸ”ć€Release Note怑iHost Update - eWeLink CUBE v2.14.0
Hello @MiAutomations ,
Episode 2 | eWeLink CUBE
The link above mentions: ā€œPlease make sure that the bootloader of the Raspberry Pi you are using is the latest version.ā€
Please refer to the official instructions below to update the bootloader to the latest version, and then check whether this resolves the issue you are experiencing.
Raspberry Pi computer hardware - Raspberry Pi Documentation
Yes the bootloader is already in the last available version
will be there a v.2.14.1 for docker or its not needed ?
Our test team found that the Raspberry Pi flashing tool sometimes causes this issue on the Pi 5 — it looks like the flash succeeded, but the Pi 5 won’t boot the internal OS (no such problem on Pi 4). They noticed that in this case the two LEDs under the Ethernet port stay off. Could you check if that’s what you’re seeing?
Try reflashing the 2.14.1 CUBE OS with the official Raspberry Pi flashing tool. If it still fails, please try several times. I tested with a Pi 5 and it booted fine.
2.14.1 CUBE OS image link:Releases Ā· eWeLinkCUBE/CUBE-OS
CUBE OS 2.14.1 is now available as well.
Seems not yet
Thanks for your feedback! I’ll confirm the latest update on the CUBE OS Docker version and get back to you. Thanks for your understanding and support.
