This release expands device compatibility in iHost and further improves the SONOFF TRVZB experience. Please take a moment to read through the notes before updating to this version.
New Features:
Added support for SONOFF MINI-ZB1GP / MINI-ZB1GSP single-channel Zigbee smart switches with electricity monitoring.
Expanded Matter Hub Device Support
Matter Hub now supports the following Matter device types:
Temperature Sensor
Contact Sensor
Occupancy Sensor
Light Sensor
Air Quality Sensor
Smoke CO Alarm
Generic Switch
Dimmable Plug-in Unit
Eligible Zigbee sub-devices connected through SONOFF NSPanel Pro 86-Relay and Bridge-M can now be synced to eWeLink CUBE via either the eWeLink Smart Home Add-on or the built-in āAdd eWeLink-linked Devicesā feature.
Optimization:
Optimized the temperature graph in CUBE CAST with a dynamically adjusted axis based on temperature data.
Bug Fixes:
Fixed an issue where a blank pop-up box was displayed when configuring temperature and humidity reporting for IKEA air quality sensors.
Fixed an issue where SONOFF SNZB-02M could incorrectly show air pressure comfort as out of range when no air pressure comfort range was configured.
Fixed an issue where the Node-RED add-on could not be downloaded, installed, or upgraded to the latest version.
Hello, we apologize for the slight change in the version schedule. Due to adjustments in requirement planning, the features originally scheduled for version 2.11.1 have now been merged into version 2.12.0. Support for the NSPanel86PāRelay via the eWeLink Smart Home addāon will also be compatible in version 2.12.0. We expect to release the new version within the next couple of days. We kindly ask for your patience a little longer. If you have any questions, please feel free to reach out. Thank you again for your support!
The SNZB-02WD device added to iHost via the built-in function (Add eWeLink-linked Devices) does not update the temperature. Bug reported as feedback 274894
Hello, thank you for your feedback. We apologize for any inconvenience this may have caused. Please be informed that this issue will be fixed in version 2.13.0. We kindly ask for your patience and understanding.
Hi there, after the recent update I get this message when I go into the Docker section on the iHost and I have tried everything to fix it except a factory reset.
Hello, thank you for your feedback. We apologize for any inconvenience this may have caused. To help us locate the issue as soon as possible, could you please provide the iHost logs?
The instructions for obtaining the logs are as follows. If the log file is too large to upload successfully, we recommend uploading it to Google Drive and sharing the link with us via the iHost feedback feature.
I have over 50 devices, so a factory reset is out of the question. Iāve suggested multiple times that they should implement a way to back up, restore, and transfer all paired devicesāalong with their scenesāto the same or a different unit, without having to set everything up again from scratch. Simply put, they havenāt done it so far, and in my opinion, they never will.
