šŸŒć€Release Note怑Standalone Image Update - eWeLink CUBE OS v2.12.0
:man_technologist:ā€ć€Release Note怑eWeLink CUBE OS Standalone Image Version History
CUBE OS v2.12.0 [2026/07/07]
CUBE OS v2.12.0 Now Officially Released!
This release expands device compatibility in CUBE OS and further improves the SONOFF TRVZB experience. Please take a moment to read through the notes before updating to this version.
What’s New?
  1. New Device Support
  • Added support for SONOFF MINI-ZB1GP / MINI-ZB1GSP single-channel Zigbee smart switches with electricity monitoring.
  1. Expanded Matter Hub Device Support
  • Matter Hub now supports the following Matter device types:
    • Temperature Sensor
    • Contact Sensor
    • Occupancy Sensor
    • Light Sensor
    • Air Quality Sensor
    • Smoke CO Alarm
    • Generic Switch
    • Dimmable Plug-in Unit
  1. Enhanced eWeLink-linked Device Sync Support
  • Eligible Zigbee sub-devices connected through SONOFF NSPanel Pro 86-Relay and Bridge-M can now be synced to eWeLink CUBE via either the eWeLink Smart Home Add-on or the built-in ā€œAdd eWeLink-linked Devicesā€ feature.
  1. SONOFF TRVZB Enhancements
  • Optimized the temperature graph in CUBE CAST with a dynamically adjusted axis based on temperature data.
Bug Fixes
  1. Fixed an issue where a blank pop-up box was displayed when configuring temperature and humidity reporting for IKEA air quality sensors.
  2. Fixed an issue where SONOFF SNZB-02M could incorrectly show air pressure comfort as out of range when no air pressure comfort range was configured.
  3. Fixed an issue where the Node-RED Add-on could fail to install or update on some devices.
