āćRelease NotećeWeLink CUBE OS Standalone Image Version History
CUBE OS V2.9.0 [2026/02/12]
CUBE OS V2.9.0 Now Officially Released!
This release expands eWeLink Smart Home Add-on compatibility and device support, with notable improvements to Zigbee reliability, automation stability, and device control flexibility. Please take a moment to read through the notes before updating to this version.
Whatās New?
- Expanded eWeLink Smart Home Add-on Device Support
Added support for syncing eligible air quality monitors to CUBE via eWeLink Smart Home Add-on, including:
- SONOFF SAWF-07P
- SONOFF SAWF-08P
Added support for SONOFF SNZB-04PR2 Door/Window Sensor.
- Sensor Accuracy & Calibration Enhancements
- Added an option to adjust temperature and humidity offsets for SONOFF SNZB-02P to improve reading accuracy.
- SONOFF TRVZB Enhancements
- Boost Mode and Temp. Override Mode can now be enabled or disabled directly from CUBE CAST.
- SONOFF SNZB-02LD can now be used as an external sensor for more accurate room temperature and humidity measurements.
- Zigbee Reliability Improvements
- Optimized Zigbee offline detection logic to identify device disconnections faster and improve overall control reliability. (Note: Due to reporting interval limitations, legacy SNZB-01 / SNZB-02 / SNZB-03 / SNZB-04 sensors are excluded from this optimization)
- Device Control & Calibration Enhancements
- Added an option to configure extra travel time for SONOFF MINI-ZBRBS to ensure blinds fully open and close during manual calibration.
- Added stepping control support for SONOFF MINI-ZB2GS, allowing external switch presses to cycle through predefined relay states for more flexible multi-state control scenarios.
- Added a manual calibration option to SONOFF MINI-ZBDIM dimming calibration.
Bug Fixes
- Fixed a bug where input capability of Frient IOMZB-110 module was missing in eWeLink CUBE.
- Resolved a control issue with Tuya/Moes AM43-0.45/40-ES-EZ curtain motor.
- Fixed an issue where Paulmann Gen2 RGB Remote could not be used as a scene trigger.
- Corrected an issue where the SONOFF R5 remote did not trigger automations as expected after restoring from a backup.
- Fixed an issue where scenes had to be re-enabled after an eWeLink CUBE reboot to run again.
- Fixed an intermittent issue where the Matter Bridge could become unresponsive on third-party platforms when synchronizing a large number of devices.
- Optimized the logic for synchronizing water leak sensors via the Matter Bridge.
