šŸ”ć€Release Note怑iHost Update - eWeLink CUBE v2.13.0
:house_with_garden:怐Release Note怑eWeLink CUBE on iHost Version History
iHost v2.13.0 [2026/08/10]
This release expands Zigbee and Matter Bridge compatibility, and improves eWeLink-linked device syncing, backups, scenes, and device stability. Please take a moment to read through the notes before updating to this version.
What’s New
  • New Device Support
    • Added support for SONOFF MINI-ZB1GS single-channel Zigbee smart switch.
    • Added support for SONOFF SNZB-09P Zigbee indoor siren.
    • Added support for SONOFF TRV-ZBT Zigbee/Bluetooth dual-mode thermostatic radiator valve.
  • Expanded Zigbee Device Support
    • Added support for the following Zigbee device types:
      • Water Valve
      • Flow Sensor
      • Rain Sensor
      • Soil Sensor
      • Air Purifier
  • Matter Bridge Enhancements
    • Added support for syncing the following Zigbee device types to Matter-enabled platforms via Matter Bridge:
      • Flow Sensor
      • Rain Sensor
      • Soil Sensor
      • Air Purifier
    • Now supports syncing energy metering data from connected Zigbee devices to Matter-enabled platforms, including total energy exported and consumed.
  • Enhanced eWeLink-linked Device Sync Support
    • SONOFF WS01TPE-E Matter-over-Wi-Fi smart wall socket with energy monitoring can now be synced to eWeLink CUBE via either the eWeLink Smart Home Add-on or the built-in ā€œAdd eWeLink-linked Devicesā€ feature.
  • System and Feature Improvements
    • Added imperial gallon as a volume unit option for the following SONOFF smart water valves:
    • Single-channel valves: SWV-ZNU / SWV-ZNE
    • Dual-channel valves: SWV-ZF2U / SWV-ZF2E
    • Downloaded backup files now use the same file names shown in the system backup list.
    • Optimized scene configuration for SONOFF THR316D temperature and humidity monitoring switch, allowing temperature to be set as a scene trigger even when it’s switched ā€œoffā€.
Bug Fixes
  • Fixed two issues with Automatic Backups: edited schedule times were displayed incorrectly, and more than one automatic backup task could be created.
  • Fixed the confirm button remaining inactive after entering a temperature threshold for SONOFF SAWF-08P.
  • Fixed an issue where restarting CUBE could create duplicate IKEA DIRIGERA devices on Matter-enabled platforms and leave them unresponsive.
  • Fixed an issue where temperature data from SONOFF SNZB-02WD did not update after the device was synced using ā€œAdd eWeLink-linked Devicesā€.
  • Fixed an issue where a SONOFF THR316D synced using ā€œAdd eWeLink-linked Devicesā€ could not be used as both a trigger and an action in the same scene.
  • Fixed an issue where room assignments, accessory names, scenes, and automations for SONOFF TRVs in Apple Home could be lost after a CUBE restart.
if i may ask , we got plenty of matter and matterbridge updates , why until now no support for adding locks at matterbridge ?
I’m a little disappointed to see that you didn’t solve the problem with the accidental logout of the eWelink Smart Home addon and the falling cameras either. Everything is for the DOCKER.
I have an Aqara Light Sensor T1 (GZCGQ11LM, manufacturer LUMI, model lumi.sen_ill.agl01) paired directly with my iHost.
The sensor was working normally with iHost firmware 2.12.0 and was reporting illumination correctly.
After updating iHost from 2.12.0 to 2.13.0, the sensor stopped reporting data.
In iHost it now shows:
  • Battery: Unknown %
  • Illumination: -- lux
The last valid illumination value was received at approximately 07:40 on August 11.
Other Zigbee devices connected to the iHost are working normally. I also use the illumination value in Node-RED, but the issue is not related to Node-RED because the illumination value is already missing directly in the iHost device interface.
I have not removed or re-paired the Aqara sensor yet because it was working correctly before the 2.13.0 firmware update.
Could you please check whether there may be a regression in Zigbee support for the Aqara Light Sensor T1 (lumi.sen_ill.agl01) in iHost 2.13.0?
I have attached a screenshot showing the current device status in iHost.
Thank you.
P.S.- I also restarted the iHost after noticing the issue, but the Aqara sensor still shows Battery: Unknown % and Illumination: – lux after the restart.
I’m having the same problem after updating to v2.13.0. Removing the battery from the sensor didn’t fix the problem.
The updates are disastrous on a Micro***t level.
The lock device type is already on our support roadmap. However, since this type of device involves a higher level of security, we need to proceed with extra caution in terms of adaptation and integration. We kindly ask for a bit more time. Thank you for your understanding and support.
Regarding the camera drop‑out issue you reported, there are two main causes:
  1. In scenarios such as refreshing the camera page, old resources were not released in time, which prevented playback from starting properly. This issue has been fixed in version 2.13.0 – we kindly ask for your patience until this release is officially available.
  2. During playback, if the camera stops streaming video for more than 2 seconds, the system may determine that the connection has been lost and stop playback. The fix for this requires more comprehensive validation, so it is not included in this release.
In addition, our R&D team is still investigating the auto‑logout issue with the CUBE OS add‑on. We will keep you updated as soon as we have any progress.
We appreciate your understanding and support.
We have not been able to reproduce the issue you reported so far. To help us locate the problem more quickly, please provide your iHost logs following the instructions below. Instructions on how to obtain the logs are provided in the attached guide. If the log file is too large to upload directly, we recommend uploading it to Google Drive and sharing a link that does not require access approval, as shown in the attached image.
Thank you for your feedback. Could you please confirm whether the issue you are seeing on your device is exactly the same as what steni reported? If it is not exactly the same, we would also kindly ask you to provide a log file following the instructions above, so that we can locate the issue as quickly as possible. We appreciate your support.
I attached logs. Feedback ticket iD 276971
will it will be published for cubeOS ?
it’s the same problem
We have recently released a hotfix package, version 2.13.1, which addresses the issue where some sensor devices displayed ā€œunknownā€ or ā€œā€“ā€ for their measured values or statuses.
You can update to this version from the eWeLink CUBE version section in your iHost settings. We sincerely apologize for any inconvenience this may have caused.
Thank you for your understanding and continued support.
The CUBE OS distribution is scheduled to be released this week. After the release, my colleague KwayLi will post the version release notes in the forum.
Afer update on 2.13.1 sensor work again. Thank you for quick response.
Thank you for your feedback. The issue you reported has been fixed. You can update the hotfix package from the eWeLink CUBE version section in your iHost settings. We sincerely apologize for any inconvenience this may have caused.
We appreciate your understanding and continued support.
What is the status of the virtual thermostat in CubeOS that you promised a while back???
I’ve found a new bug with the SNZB-02 M device. The Pressure Offset cannot be set in the device menu. Pressing the plus and minus buttons still returns a zero offset.
Feedback ID277111
