āćRelease NotećeWeLink CUBE OS Standalone Image Version History
CUBE OS v2.14.0 [2026/09/18]
CUBE OS v2.14.0 Now Officially Released!
This release expands Matter Bridge capabilities and device support, and improves eWeLink-linked device syncing, scenes, CAST, Node-RED, and overall stability. Please take a moment to read through the notes before updating to this version.
Whatās New?
- New Device Support
- Added support for SONOFF S61SZBTPB Zigbee smart plug.
- Enhanced eWeLink-linked Device Sync Support
- The eWeLink Smart Home Add-on and built-in āAdd eWeLink-linked Devicesā feature now support syncing:
- SONOFF Hydro ONE smart water valves (SWV-ZFE / SWV-ZFU)
- SONOFF Hydro ONE Lite smart water valves (SWV-ZNE / SWV-ZNU)
- SONOFF Hydro DUO dual-channel smart water valves (SWV-ZF2E / SWV-ZF2U)
- SONOFF MINI Extreme Zigbee Dimmer Switch (MINI-ZBDIM)
- Matter Bridge Enhancements
Added support for syncing the following Matter/Zigbee device types to Matter-enabled platforms via Matter Bridge:
- Pressure Sensor
- Siren
Expanded Air Quality Sensor support with the following measurement capabilities:
- Formaldehyde Concentration
- Nitrogen Dioxide Concentration
- Ozone Concentration
- PM1 Concentration
- PM10 Concentration
- Radon Concentration
Expanded Boolean State Configuration cluster support for:
- Occupancy Sensors now support sensitivity adjustment.
- Water Leak Detectors now support enabling or disabling tamper alerts.
Optimized color-light mapping to ensure color adjustment works correctly after bridging to Samsung SmartThings.
Changed Matter Bridge mapping for multi-function devices to use multiple endpoints instead of compose, improving device compatibility.
- Device and Automation Enhancements
SONOFF BASIC-ZB1GSP now supports bi-directional energy monitoring, allowing users to view up to 12 months of energy history.
Scene triggers based on power consumption now support value ranges.
CAST now supports white and color light controls for compatible lights.
Expanded the following control capabilities for the Node-RED control-device node:
- Power Percentage
- Valve Position
- Irrigation/Work-mode
Added support for viewing Tamper Alert event logs.
Bug Fixes
- Resolved scene execution issues when energy consumption from devices synced via eWeLink Smart Home Add-on was used as a trigger.
- Corrected battery status display when the reported battery level was 0%.
- Fixed an issue where the thermostat control page in CAST could appear blank.
- Fixed an issue where RTSP streams from Yoosee cameras could not be viewed on CUBE.
- Fixed an issue where Matter Hub could repeatedly restart when removing devices added through another Matter Bridge.
- Fixed Docker data restoration failure for backups created in versions 2.12.0 or later.
- Fixed reverse-direction control issues affecting more than 10 third-party Zigbee curtain motor models, as well as calibration issues on some devices.
- Fixed an issue where the SONOFF SNZB-06P24 Presence Sensor reported illuminance values too frequently.
