šŸ‘Øā€šŸ’»ā€ć€Release Note怑eWeLink CUBE OS v2.10.3/v2.10.2 Standalone Image Update
:man_technologist:ā€ć€Release Note怑eWeLink CUBE OS Standalone Image Version History
CUBE OS v2.10.3 [2026/05/27]
CUBE OS v2.10.3 Now Officially Released!
This release introduces built-in eWeLink Smart Home for easier device syncing, One-click Installation on Mac, and adds support for running CUBE OS in Docker environments for more flexible deployment options. Please take a moment to read through the notes before updating to this version.
What’s New?
  1. Built-in eWeLink Smart Home for Easier Device Sync
  • A simpler way to sync eWeLink-linked devices is now available in CUBE. Sign in with your eWeLink account from Home > Add Device to sync and manage eligible devices directly in CUBE, without installing the eWeLink Smart Home Add-on.
    Note: Existing add-on devices will continue to work independently.
  1. Docker Deployment Support
  • CUBE OS can now run in Docker environments, giving users more flexible deployment options.
    For Docker-based deployments, the following system-level features are not available:
    • Docker (Add-ons)
    • Pilot Features > Bluetooth Speaker
    • Settings > Gateway Info > Version Update
    • Settings > Reboot & Shutdown
  • To update a Docker-based deployment, pull the latest Docker image.
  1. Expanded One-click Installation Support
  • Added support for one-click installation of CUBE on Mac.
CUBE OS v2.10.2 [2026/05/18]
CUBE OS v2.10.2 Now Officially Released!
This release introduces SONOFF Dongle firmware management, expanded deployment options, and new device support, while further improving Matter Bridge compatibility, Zigbee device behavior, and overall system stability. Please take a moment to read through the notes before updating to this version.
What’s New?
  1. SONOFF Dongle Firmware Management
  • Added automatic detection for connected Zigbee Dongles. Unsupported SONOFF Dongles can now be upgraded to recommended stable Zigbee firmware versions with one click:
    • Ember-based Dongles with firmware versions earlier than v7.4.5 will be upgraded to v8.0.2.
    • ZStack-based Dongles with firmware versions earlier than v20250321 will be upgraded to v20250321.
  • After upgrading CUBE to v2.10.2, connected SONOFF Dongles will be automatically upgraded to the recommended stable firmware versions. Non-SONOFF Dongles must be upgraded using their official flashing tools to ensure proper connection and device control.
  • Optimized Zigbee offline detection behavior:
    • Router devices report within 1 minute
    • End devices report within 1 hour
    • Devices exceeding the reporting interval will appear offline until triggered again.
  1. Expanded Deployment Support
  • Added support for one-click installation of CUBE on Windows.
  1. Matter Bridge Enhancements
  • Upgraded the CUBE Matter Bridge SDK to v1.5.0.
  • Optimized the default device naming when syncing devices to SmartThings and Alexa via Matter Bridge.
  1. SONOFF TRVZB Enhancements
  • Added Adaptive Mode for SONOFF TRVZB, configurable in the eWeLink App, to help maintain a more stable room temperature.
  1. New Device Support
  • Added support for SONOFF Hydro ONE Zigbee Smart Water Valves (SWV-ZFU / SWV-ZFE) and SONOFF Hydro ONE Lite Zigbee Smart Water Valves (SWV-ZNU / SWV-ZNE).
  • Added support for SONOFF MINI-ZBD Smart Dry Contact Module.
  1. Zigbee Device Compatibility Improvements
  • Optimized power-on behavior configuration for third-party Zigbee devices.
  1. Shutdown Feature
  • Added a shutdown option in the CUBE Web settings page.
Bug Fixes
  1. Fixed an issue where Raspberry Pi 5 Rev1.1 boards could fail to boot properly.
  2. Fixed an issue where devices could fail to sync to Alexa via Matter Bridge.
  3. Fixed timeout issues when adding ONVIF / RTSP cameras.
  4. Fixed the issue where the status of the HOBEIAN ZG-102ZM vibration sensor did not update.
  5. Fixed the issue where the historical data chart of Zigbee plugs was not displayed.
Click :down_arrow: to Explore CUBE OS More in
dfa956754df2fd4627eadfd400b5c898
Hi @KwayLi99
Does the Cube Os development roadmap for this year include making camera feeds available to Matter via Matter Bridge?
Hello, we are currently planning this feature. Could you share any specific requirements or suggestions you have for it? For example, which camera brands would you like to see supported, or what kind of automation effects (such as motion detection triggering scenes) would you expect? Your feedback will directly help us improve the feature design. Thank you for your support!
I use a Sonoff CAM Pan-Tilt 2 camera and plan to also purchase a Sonoff Cam-B1P. The Pan-Tilt 2 camera is included with CubeOs. I’d like to send the camera’s image via the Matter bridge to the SmartThings platform. I also need to control the camera’s rotation and use motion detection for various automations.
Does the Cube OS development roadmap include the ability to backup manual and automatic scenes? This is an essential feature as developments continue and the complexity of the automation we make increases and also in case of a hardware failure. I use a Raspberry Pi and SD cards can get corrupted in the event of a power failure.
There are backup & restore features already. It can not only backup the scenes (manual / automatic) but also the devices and other configurations. Of course it is not make sense to just backup the scenes, when devices not available anymore. It works and I use it several times since version 2.8.1. But you still need to download the backup file manually and save it somewhere else if you worry your raspberry pi may have issue.
Is this 2.10.3 coming slowly?
It still not pushed to my device.
Or is this version not suitable for IHost?
Hi, this post is for the CUBE Standalone Image version. The latest update for CUBE on iHost (v2.11.0) was released yesterday. You can find the release note here: šŸ‘Øā€šŸ’»ā€ć€Release Note怑eWeLink CUBE v2.11.0 on iHost Update
