šŸ‘Øā€šŸ’»ā€ć€Release Note怑eWeLink CUBE OS v0.5 Beta Update - Standalone Image on Raspberry Pi & Virtual Machines
CUBE OS v0.5 [2025/08/27]
CUBE OS v0.5 Now Officially Released!
This update brings extended Zigbee dongle compatibility, ONVIF camera enhancements, and notable improvements for CUBE CAST. Please take a moment to read through the notes before updating to this version.
What’s New
  1. Expanded Zigbee Dongle Compatibility
  • Added support for SONOFF ZBDongle-P and SMLIGHT SLZB-06 Zigbee Coordinator.
  • Currently tested and verified compatible dongles:
    • SONOFF ZBDongle-E / P
    • SMLIGHT SLZB-06 / 06M
    • SkyConnect Zigbee (EZSP)
  1. ONVIF Camera Support
  • Added automatic discovery of ONVIF-compatible cameras.
  • Supported PTZ (Pan-Tilt-Zoom) control.
  • Tested and verified compatible devices (with required firmware versions):
    • SONOFF CAM-PT2: FW ≄ 1.0.6
    • SONOFF CAM-B1P: FW ≄ 1.0.2
  1. CAST Enhancements
  • Extended CAST pad layouts for a more flexible dashboard experience.
Bug Fixes
  1. Fixed an issue where CUBE OS failed to boot on Raspberry Pi 5 and could not perform OTA updates.
  2. Corrected inaccurate data display in thermostatic radiator valves’ trend graphs.
  3. Fixed a bug where scenes triggered by power thresholds failed to execute properly.
  4. Fixed an issue where device status updates on CAST required a manual browser refresh.
:wrench: How to test
  1. Download the firmware Grab it from GitHub and flash it to your preferred device.
  2. Join the public Discord server
  3. Submit your feedback Share bugs, device compatibility notes, or suggestions - we’re listening.
How do I update from version 0.4 to 0.5 without losing settings or having to create a new virtual PC?
CUBE OS has a built-in OTA feature that will automatically download the latest firmware package. Once the download is complete, you can select to confirm the installation here.
thank you, the update went well, I have another question, does it support wifi pairing or only devices with mettre support? is it possible and how to pair devices with ewelink support in the weifi OS itself?
@spoustaml Thank you for your question. In this beta version, the Wi-Fi feature is not supported yet. To connect SONOFF/eWeLink Wi-Fi devices, you can use the eWeLink Smart Home Add-on to sync the devices from the app to CUBE OS for local control; you can refer to the initial steps of this tutorial.
However, your suggestion to pair directly with Wi-Fi devices is on our roadmap, and we plan to implement this in future versions, so please stay tuned!
thank you for the answer and I look forward to it
Which version of the Home Assistant in Docker is 32-bit or 64-bit?
The version you need depends on the architecture of your host machine. You can find the corresponding version for your architecture on Docker Hub.
https://hub.docker.com/r/homeassistant/home-assistant/tags
What you are currently using to install CUBE OS?
I’m waiting for the raspberry pi5 I ordered, but in the meantime I’m considering my options.
