🚀 eWeLink CUBE OS v0.4 Beta – Self hosted eWeLink server - Public Testing Now Open!
Following the successful completion of our internal beta test, we’re thrilled to announce that the second phase of testing for eWeLink CUBE OS v0.4 is officially underway — and this time, it’s open to everyone!
Whether you’re running a Raspberry Pi, NAS, or virtual machine, you can now get hands-on with our standalone smart home OS and experience local control, Zigbee integration, Matter bridging, and more.
:puzzle_piece: What’s New in Phase 2?
  • :white_check_mark: No application needed – the image is now available publicly on GitHub
  • :white_check_mark: Join our Discord directly – the server is now open to all testers, no approval required eWeLink CUBE
:light_bulb: Key Features to Explore
  • Plug-and-play support for Zigbee devices (with SONOFF ZBDongle-E recommended)
  • Matter Hub & Matter Bridge (to Apple Home, Google Home, Alexa…)
  • Cast dashboard, Docker & Add-on support, remote access, OTA upgrades, and more
Below is a list of key features available in this release:
No. Feature Virtual Machine Raspberry Pi (4B/5) Notes
1 Zigbee Cluster Support :warning: (Zigbee dongle needed) :warning: (Zigbee dongle needed) 1. Supported Zigbee dongles: - Sonoff ZBDongle-E (recommended) - Others listed by developer @darkxst 2. Supported Zigbee clusters: cube-web.ewelink.cc
2 Matter Hub :warning: :warning: *Requires target platform with Bluetooth capability
Supported Matter clusters:
- Switches and plugs (On/Off Plug-in Units)
- Lights, including:
  - Dimmable Light
  - On/Off Light
  - Extended Color Light
- Bridge-type devices
Bridge integration:
Devices connected under a Matter Bridge — including switches/plugs and supported light types (Dimmable Light, On/Off Light, Temperature Light, Extended Color Light) — can be synchronized and added to CUBEOS via the bridge.
3 Matter Bridge :warning: :warning: *Under certification testing, may encounter issues on certain Matter fabrics.
- On/Off Plug-in Unit
- Dimmable Light
- Color Temperature Light
- Occupancy Sensor
- Contact Sensor
- Humidity Sensor
- Temperature Sensor
- Generic Switch
- Thermostat
- Window Covering
4 Remote Access :white_check_mark: :white_check_mark: Implemented via PWA (Progressive Web App). Chrome and Safari are recommended.
5 Push Notifications :warning: :warning: Only available via eWeLink CUBE CAST Dashboard
6 CAST Dashboards :white_check_mark: :white_check_mark:
7 Docker & Add-ons :white_check_mark: :white_check_mark: Stored locally on the target platform
8 Backup / Restore :white_check_mark: :white_check_mark:
9 Scenes (Smart / Manual) :white_check_mark: :white_check_mark:
10 Groups / Rooms :white_check_mark: :white_check_mark:
11 Firmware OTA :white_check_mark: :white_check_mark: Supports OTA for both CUBE and Zigbee sub-devices
12 Turbo Mode (Zigbee) :white_check_mark: :white_check_mark:
  • Compatible with:
Raspberry Pi 4 & 5 (min. 4GB RAM, 8GB recommended)
x86_64 Virtual Machines (min. 6GB RAM)
NAS devices (tested on Synology; setup may vary)
:wrench: How to Join
  1. Download the firmware→ Grab it from GitHub and flash it to your preferred device.
  1. Join the public Discord server
  2. Submit your feedback → Share bugs, device compatibility notes, or suggestions — we’re listening.
:warning: Reminder
This is still a beta release. We strongly recommend testing on non-production environments. Expect occasional bugs or missing features — and please let us know when you encounter them!
We can’t wait to hear what you think. Your feedback is what drives CUBE OS forward!
Hello
I just installed CUBE OS on a Raspberry Pi 4 with successful results.
I have also uploaded the translation package for the i-HOST 2.6.2 version that I translated myself into Catalan and also into Spanish and apparently, it has worked even though the language script of the CUBEOS 0.4.0 version (9122 lines) has fewer lines than that of the i-HOST.
And I would like to translate into Catalan and Spanish in the same way that I translate for the i-HOST
I can traslate for CUBEOS too !!!
You can find the files for download in the corresponding section of the Language Files Contribute.
For example you can download CATALAN for your Raspberry Pi 4/5 (eWeLink CUBE 0.4.0)
(9122 lines, 17/8/25)
and the same for SPANISH
Greetings
Adolfo Rupérez
Thanks for your contribution! We’re very appreciative of it! :beating_heart:
it is possible to connect wifi devices locally
Close this topic.
Please check the new release V0.5 for more information.
