eWeLink CUBE V2.0.0 is now available via SONOFF iHost, let us know about your thoughts!
New Features:
Device pages now display card components based on device capabilities.
Added āDisplay Asā feature, now you can choose default icons or upload images to customize unique icons.
Optimizations:
Optimized the process of adding Zigbee sub-devices, reducing the pairing time.
Optimized the default device icons.
Single-click, double-click, or long-press now can be set as triggers for wireless switches in smart security.
Due to the official discontinuation of āoznu/homebridgeā add-on maintenance, it has been replaced with āhomebridge/homebridgeā in the iHost docker add-on list. Users can manually uninstall it and then run the āhomebridge/homebridgeā add-on to ensure continued maintenance. Please kindly note that data from the āoznu/homebridgeā add-on cannot be migrated to āhomebridge/homebridgeā add-on.
Bug Fixes:
Fixed the issue where the Internet could not be accessed after re-plugging the Ethernet cable.
Resolved the problem where the reconnection audio played repeatly after re-plugging the Ethernet cable.
homebridge is showing token error. However, the entire configuration is correct!
iHost in version 1.14 is normal but in version 2.0 it has this problem!
2.0 is not work corretly.
When working through tailscale, a blank screen opens.
when working directly, it is not possible to update dockers, the buttons are located outside the screen and there is no scrolling either
There is nothing to share in my humble opinion, guys.
Itās a 1.14 without a buzzer noise, played on a loop randomly at night, which was annoying my wife. I appreciate the new icons and other changes, but they donāt address any of the criticisms users have voiced over the past several months. Unless something massive happened deep āunder the hood,ā this is a plain boring nothingburger. Cool for 1.14.3. 2.0? Nah⦠Cheers.
Nope. Went for HA@pi5 a month ago. Iām pulling the plug on iHost and Sonoff altogether. Given current progress CUBE wonāt meet my expectations even in version 117.0
