šŸ‘Øā€šŸ’»ā€ć€Release Note怑eWeLink CUBE V2.5.2 Update
V2.5.2 [2025.05.12]
iHost V2.5.2 Now Officially Released!
In this update, V2.5.2, introduces support for new smart plugs and enhances the sensor display and Matter Bridge compatibility.
New Feature:
  • Added support for smart plugs: SONOFF S60ZBTPF and S60ZBTPG.
Optimization:
  • Improved consistency between the data displayed on Temp.&Humi. Sensor tiles and the corresponding control pages.
Bug Fixes:
  • Addressed a bug where SONOFF ZBMINIR2 failed to switch between trigger modes.
  • Fixed a bug where the SNZB-02LD sensor failed to sync to the added Matter platforms via Matter Bridge.
Just curious, power and current from tuya plugs with monitoring connected to ihost cant share data over matter.how about new plugs S60ZB?
On the home page there is a room for new devices - Unassigned. I would like to have the ability to access this room to put unused devices from other rooms there. Is this possible?
Also need a feature to hide devices that are offline.
Is this possible? :index_pointing_up:
you can create a new room with name unsed and move the devices to it , the unassigned room for non mapped devices only
I know I can do that, but I don’t want to create extra rooms if there’s already an unused one.
actually the unassigned like a space not a room , maybe you want a room with option hide so you can hide some devices with their room totally from app
i like your suggestion , the ability to hide a device , not necessary to be online or offline , just being able to hide it in case was senstive switch that dont want to hit by mistake
Yes, you’re right. Including hide the sensitive switch
I can confirm that we will add the feature to hide offline devices to our roadmap. However, regarding the configuration for unassigned devices, we may not consider it at this time. Thank you for your understanding.
@KwayLi99 When will the Ewelink Cube Ihost update be available?
When will the Ihost support Mini-RBS via the ewelink smart home add-on?
can you add CAM PAN-TILT camera control to Ihost?
Currently ihost can only display image and sound via RTSP
Hi.
I know HA is currently the priority on iHost, and I’m very happy about that. :grinning_face:
But I’m curious about the situation with the eWeLink Cube iHost? :thinking:Will a new update be released in July?
There will be, expected on the 17th if things going well, Mainly focused on the optimization of the Matter bridge and the scene part.
Request received, will make it happen asap.
Will Matter Server support new devices like motion sensors, light sensors, etc.?
If not, when do you plan to introduce new devices to Matter Server?
Are there any plans to run multiprotocol on ihost?
Motion sensors expected be available on the 7.17 release, while light sensors on the Aug. release, with the Matter Sdk upgrade to office spec V1.4.
You mean zigbee and thread?
Yes, zigbee and thread
Far as i know, good news is that the multipan (run zigbee coordinator and ORTB simultaneously ) feature is under validation stage, if we soomth all the tech part, will gradually deploying the firmware to gateways.
Hi there. We urgently request the following improvements for the iHost interface:
  1. Dark theme.
  2. On mobile phones, the right side of the iHost screen is not visible.
  3. Scenes should have a lock option. Right now, it’s too easy to accidentally drag and rearrange them with the mouse, and the layout gets messed up.
  4. All scenes should be viewable in a detailed list format, without having to open each one individually. There should also be an option to export or download this data, so we don’t have to recreate everything manually in the future.
  5. On the iHost Home screen, device positions can be accidentally moved with the mouse. There should be a lock button in the UI to prevent this kind of mistake.
  6. In the iHost Home section, device icons or images should be shown larger. Currently, it’s impossible to tell what the devices are from the visuals. Even if we upload our own icons, it’s still unclear because everything is white and there’s no theme.
  7. In the Cast section, we should be able to customize the size of all added devices as we wish.
  8. In the Cast section, when running scenes, only a small message appears at the top. There should be some animation or visual effect to clearly show that a scene was activated.
Please consider these improvements. They would make iHost look much more stylish and user-friendly. Visual enhancements are very much needed.
