šŸ‘Øā€šŸ’»ā€ć€Release Note怑eWeLink CUBE V2.9.0 on iHost Update
This device can currently be added directly through the ZB scan on iHost without needing to sync via the add-on. Please give it a try to add it directly on iHost.
Let me know if you need any further assistance!
Please wait for a moment. I’m currently confiming this with our product team.
I apologize for the inconvenience this has caused you. I will now elevate the priority of this issue, and we are actively reviewing your ticket. Thank you for your understanding, and I will keep you updated!
Si, ho risolto! Finalmente posso mandare in pensione lo ZBBridge-P!
Grazie mille per la puntuale assistenza
The issue resolved after upgrading eWelink Smart Home Add-on with today’s version
Hi @KwayLi99
The Ewelink Smart Home add-on (v2.7.3) added SAWF-07P and SAWF-08P devices to IHOST
In the SAWF-07P device menu, there is no PM 10 threshold setting. (Excellent; Good; Unhealthy)
[MATTER BRIDGE ERROR]
Devices transferred via Matter Bridge to Home Assistant and Smartthings do not display air quality information.
Additionally, the SAWF-07P device does not provide PM10 values.
OK. Let us try to reproduce this issue and address it.
@KwayLi99 could you or one of your colleagues please update this thread, if and when any revisions are released? I’d like to hold off updating until any issues are resolved.
Since this morning, the valves no longer communicate with iHost. They are visible among the devices and their temperature is displayed, but I’m unable to control them in any way. I’ve already tried resetting them and syncing them again, but it doesn’t work.
I did a V2.9.0 update and had the same issue as V2.8.1. Lot’s of ā€˜Failed To Control’ errors and lots of zigbee devices offline. Logs submitted with this support request - 265081. You really need to find the root cause.
In Docker, the ewelink add on does not update newly added devices, and it seems like there are fewer devices there than under the ewelnik account, is there a solution for this?
You can’t install plugins in Docker. Not even your own from you.
@KwayLi99 Support timeline - Mar 31: iHost (V2.10.0)
Will this deadline be met?
Will iHost v2.10.0 support Sonoff Hydro One?
:scream: The heating season is ending, and IHOST still doesn’t support adaptive mode for TRVZB! :angry:
When will IHOST support the new HYDRO ONE valve?
What about the eWelink Cube v2.10.0 update on IHOST?
I hope that after updating to 2.10.0 iHost will run normally.
The thermostat doesn’t support it either, and there’s no way to talk about a functional matter bridge. At times, not even God knows which virtual button is on. There’s more unfinished business there. :frowning:
Hello, thank you for your attention and feedback!
Regarding the eWeLink Cube v2.10.0 update you mentioned, it is expected to be released around mid-April. This version will support the HYDRO ONE single-channel water valve, allowing you to use and control the device normally on iHost.
Thank you for your patience. We will continue to optimize the product experience. If you have any further questions, please feel free to contact us.
And when will IHOST support the WS01TPF-E?
We sincerely apologize for the unsatisfactory experience you have encountered. According to the preliminary plan, the built-in version of eWeLink Smart Home, scheduled for release at the end of May, will add support for WS01TPF-E
@KwayLi99 @Minnie
Hi
I found a bug in the iHost v2.9.0 Matter Bridge.
I added the SNZB-02LD device (Device ID:
0xa4c13800001affff) to the iHost, but the device isn’t being transferred properly to the Matter Bridge.
In SmartThings, it’s displayed as a snzb-06p device, and in Home Assistant, it’s displayed as a temperature sensor without any entities.
feedback 268746
