Backups are limited by the size of the eMMC memory. Only 1.5 GB is available for backups. If you have add-ons installed, backups will not be possible.
A Matter Bridge fix update will be rolled out very soon.
Question and then why does it start and stay blocked reaching 46% and I have to reset IHOST
If your ihost connects to the LAN via WiFi, this may be the reason the update failed. Set it to update automatically at a specific time and check if it was successful.
Wifi randomly disconecting.
When will T5 switches be supported? I mean that what works in the phone app would work in iHost as well. I use it as a doorbell, but this way the scene runs in the cloud instead of ihost...
Thanks for your feedback! Weāre actively working on updating device support for this.
Why canāt detect sonoff cam pt2? I must manuĆ”l setup camera and now nĆ“t working ptz.
The camera needs to be added in eWeLink first before it can be automatically detected and discovered on the iHost. Regarding the issue that the PTZ function does not work after your manual configuration, could you please provide the relevant logs so that we can better locate the problem? Thank you for your cooperation.
is it added in ewelink and where do you want to send the logs?
This device supports being added in eWeLink. If you have manually configured the camera in iHost but the PTZ function does not work, you can upload logs through the āFeedbackā function in the settings of iHost. Thank you.
Yes, this device supports being added to eWeLink. You can upload your logs through the āFeedbackā function in the iHost settings.
It happened to me in version 2.8.0 that the Matter bridge stopped recognizing the ZBMINIL2 relay. The ones I had integrated before the update continue to work, but when trying to integrate 2 new ZBMINIL2 devices, it tells me they are not compatible with Matter, even though they are all identical and on the same version (1.0.14).
Do you have a solution?
Thanks.
Our technical team will release a patch version in a while. After the patch version is released, you can update and try again. Thank you for your understanding.
In my case, the devices that appear in the list of non-Matter-compatible devices are virtual devices created after updating to 2.8.0.
Regards.
2.8.1 has been the solution. Thank you very much!!
It works ā¦ā¦ā¦..
Is anyone else having issues with 2.8.1? My ihost seems to be have difficulty communicating with all the zigbee devices. Iām getting lots of āFailed to Controlā messages.
I mainly have ZBTRVs on v1.4.0 but also various other sensors and buttons.
Iām still having trouble with the RTSP cameras. Iāve restarted iHost several times and linked the camera multiple times. I can never view the camera via iHost cast.
