I managed to add it to Google Home. smartthing didn’t allow me to add it because there was a message that I didn’t have a Mater hub. later I deleted ihost from Google Home and wanted to pair it again. But pairing was not possible. the application did not find the ihost device.
In the Pairing page from the Matter tab, check it there’s any connected service. If you’re under iOS, iHost will be automatically paired to Apple Keychain. Remove that from the iHost WebUI and try to pair again with Google Home.
The first time you add ihost via matter to Google Home successfully was v1.12.0 ?
as @Faber_GS say, you can clear all fabric on ihost’s web and try again.
I start pairing on ihost, a QR code is displayed, it scans in the Google Home application, it searches for the device and then there is a message to check the ihost user manual.
I also have the same problem after the update to the new version 1.12.0 I can no longer pair Alexa with ihost, several attempts but with negative results.
It stops at the credentials generating stage. It then prompts you to check the post-processing instructions and/or displays a message about the need to connect to the network.
after several attempts now my alexa is connected to iHost via matter, now I see the devices connected to ihost inside my alexa app “motion sensor, temperature sensor, energy meter, virtual device”.
But I don’t see the devices that I integrated into Alexa “coffee machine socket” in iHost.
hi ok, the names of the devices looked like alpha numeric codes like this “a4f7:tC42:dF54: …” so they included me in my Alexa app, I had to rename all the devices even iHost appeared like this!
Even the devices you had already named in iHost were now named gobbledygook? I haven’t logged into my iHost since joining Alexa to it. Luckily my node Red automations still are working. I assume under the cover the nodes use device IDs. To be honest I mostly joined Alexa to it because I wasn’t sure which year of echo dot 3 I had. I am beginning to regret it.
