What are the requirements for the WiFi connection? Seems like it wonât connect when WPA2/WPA3 are enabled or 802.11ax. (WiFi agile flag is a no-no as well, from what I gather at the moment)
WiFi agile multiband. Not sure if it is some Asus proprietary piece of software or part of the official specification.
Clarification: the ihost does connect successfully on separate SSID (guest network) when it is 2.4Ghz, WPA2, 802.11ax OFF
Sometimes a 5GHz network needs to be switched off for a while in order to connect successfully, if that network has the same SSID. This usually happens with mesh WiFi networks, with automatic switching between bands. Some WiFi modules are picky about this.
Itâs within the official specifications for multiband networks. However, implementations from one manufacturer to another may vary slightly. From reading various publications, it seems that the clientâs decision will be based more on getting information from AP. This is just an assumption, but I donât think it will do anything unless the client supports it. I guess it would be beneficial in an AiMesh environment, but less so in a single router environment - perhaps helping the transition between 5/6GHz and 2.4GHz.
It may also be marketing blah-blah until devices support it. Right now the number is close to nothing.
I understand that itâs about progress and so on. But introducing new features when existing ones still havenât found widespread acceptance is a bit of a miss. I have relatively new routers that form a mesh network, with Wi-Fi 6 and up to 2400 Mbit/s. Only two of my client devices fully support this. The others are technically halfway or lagging behind. Iâm not replacing working hardware especially as the old ones provide fully satisfactory performance in practice. The manufacturer publishes updates because problems keep coming out, e.g. with mesh and active switching of theoretically ready devices. A new version of the system is due to be released soon, which is expected to introduce further âimprovementsâ. There is much truth in the saying that the perfect is the enemy of the good.
When and if it will be available on iHost that the control capabilities of Sonoff devices will be identical to those available on the eWelink application.
The problem is that my Sonoff relays in the cloud perform smart scenes that contain, for example, a temperature difference, and there is no such thing in iHost. EtcâŚ
@teo.alex gave you a hint. Go for it. If youâre looking for more complex automations, Node-RED is the best solution. If you donât feel like programming, any solution that goes beyond scene-based automations may be difficult to handle. But this has nothing to do with iHost and its design principles. In order to create complex automations within any platform that enables this (e.g. in HA), you need to have the knowledge and the will to do it. You canât do it all with ready-made templates.
As an aside, and with all due respect, if you have managed to create working scenes within the cloud, they are not that complicated, as the scene builder does not offer such advanced capabilities. Itâs very similar to the one that sits in iHost. What is different is Node-RED. As @teo-alex wrote,
