👨‍💻‍【Release Note】eWeLink CUBE V2.5.1 Update
Yes. I need it.
We’ll support it in next version.
ok. Thanks.
sonoff BASICZBR3 also does not have this function enabled.
I have this error
Plz click the button and see if the progress bar moves:Screenshot 2024-08-29 at 18.27.59
I click refresh. appears
(Downloading …0% ). and then an error
Please give it some time and try again. It was just out, and my unit has yet to receive that update.
If your network works well for other devices, submit a ticket with logs from the settings tab.
Thx.
ATTENTION. After updating IHOST, you must delete your web browser history
Just clearing cookie of the site iHost.local should be fine. :wink:
Wow, credit, where credit is due. You are cranking these FWs now, AND they start to implement clever, useful features. @ward @suika
22 posts were split to a new topic: Please Contact SONOFF on iHost “Wi-Fi Not Available” Issue
Save doesn’t work in the cast menu. you need to create a new panel
Did you fail to set something necessary?
Can you take a screenshot of your network request in borwser console?
I didn’t understand the WI-FI function. Can it be used instead of Lan? That’s it?
It allow you to connect you iHost not only in LAN but WiFi.
Understood… I thought it was possible to use IHost as a WI-FI router.
It’s not listed on the changelog again…
https://forum.ewelink.cc/t/ihost-accessing-ntp-servers-every-5-seconds/37602/31
Hey, please kindly check again, it should have been fixed in this version.
