Good afternoon, for two days I have been having problems with the nspanel pro thermostat in automatic mode, it does not control the temperature, it connects the boiler unnecessarily and does not stop, in manual mode it works perfectly
buenas tardes , desde hace dos días estoy teniendo problemas con el termostato de nspanel pro en modo automático , no controla la temperatura,conecta la caldera sin necesidad y no para , en modo manual funciona perfectamente
Buenos días, ya está solucionado ,el problema había sido que por alguna razón ,(no se cuál ) se había cambiado la zora horaria ,entoces los horarios del termostato no cuadraban ,ha sido cambiarla zona horaria y funciona correctamente
Good morning, it is now fixed. The problem was that for some reason (I don’t know what) the time zone had been changed, so the thermostat times did not match. I changed the time zone and it works correctly.
Good for you
I set the right time (I think) but the auto mode don’t work at all
I manual mode work fine!
Moreover I think that sensors are to many times offline or too long in refresh so the temperature is always incorrect and also the impossibility to offset them to the right data (in static conditions are no so bad but in dynamic conditions fail continuously) is another gap.
I think they didn’t test the panel deep enough before send it to the market… we are their beta testers!
I have the same problem, sometimes auto works… sometimes does not action the device and house is cold… sometimes does not action the device off and heating stays on and house gets really hot. I can’t find why it does this? Intermittent working, to fix I simply switch to manual and back to auto but this really defeats the point of an auto mode.
Could we not simply have the thermostat send the action more than once? Or check it has been actioned and if not do so?? If the thermostat could be seen and controlled from other devices I feel like we could set up scenes to help with this but this is not something we can even do… feel like iv switched to this system for my heating and it’s not working out well at all. Quite annoying
Hi. I have the same problem with the new thermostat plug in. In manual mode it works fine, but when in auto, it stays on 4ever. I did set the start time at 5 every morning and then when the heater gets to set point, it is supposed to stay OFF until the next day at 5, but no, this guy stays on 4ever. As you said, what the use if i cant have it automatic.
