NS panel PRO thermostats issue
Hello everyone.
I wanted to ask, is it only me on NS panel PRO that the thermostats do not work correctly?
I have two NS Panel Pro panels. Sonoff S26R2ZB sockets are used as action devices.
I set the thermostats in manual mode to 22 degrees, in auto mode to 16 degrees (hysteresis is 0.5 degrees)
Accordingly, when I am indoors, I set the manual mode on the thermostats,
the temperature is maintained from 21.5 to 22.5.
Before leaving, I switch to auto mode, i.e. in theory the temperature should be maintained from 15.5 to 16.5 degrees.
But no. Some thermostats continue to maintain 22, as if there was no switch to auto mode.
Moreover, if this incorrectly working thermostat is set in manual mode to 16, is still maintained 22. Sometimes turning the thermostat on and off helps, sometimes deleting it and creating it again. Sometimes nothing helps.
I created tickets to technical support, sent logs, no answer.
For more than a year now I have been forced to constantly monitoring the temperature, constantly reconfiguring, deleting and creating something. I’m tired of it.
