NS Panel (not Pro) update 1.6.0
Today I installed 1.6.0
But, what is new??
I experinced some strange behaviour in the last day(s), mainly in the automatic thermostat mode, hopefully this is solved now!
Look like, some unknown features:
  • details of sharing control
  • update speed of temperature
Automatic thermostat mode - I confirm troubles after upgrade to 1.6.
Today in the morning i found heating switched off, but temperature in the room was 2 degress lower then set (have set +/- 0,5 tolerance).
I checked Nspanel and found that auto mode is on, but instead of number 21 there are two dashes (-- ) on temp. control screen. But on temperature settings screen still showed correct temperature for today: 21 !
Also try to chage the value to 22 and save. No effect on temp. control screen dashes are still there.
Fortunately manual mode works.
What the hell is going on ?
I my case the update remained updating for one whole day. The two NS Panels i operate were bricked. I was saved by an electric outage that restarted the two panels. Following the power outage the old firmware as restored, The two NS Panels continued to show that the were still updating for about seven hours before the update failed completely. That was a close shave to me because I am operating a remote site that does not give me access to tinker with any failed updates
