Im trying to connect the Sonoff NSPanel Pro to Philips Hue Bridge using Matter.
NSPanel found the Philips Hue bridge (Matter enabled), I put the Matter code and appears in EWeLink but the devices managed are 0 (I have connected to Philips Hue Bridge via Zigbee a few bulb lights).
But vendors as well as platforms are still aligning up with each other, in the meanwhile the spec is completing slowly. Different Matter bridges handle devices differently. For instance Hue would convert a plug to on/off light
