NSPanelPro 120 stuck in startup loop
Hi all,
Has anyone encountered where the NsPanelPro app itself wont start up? I keep getting “NSPanelPro has stopped” after the Sonoff logo shows on start up.
Then i have the option to “Open app again” but it doesn’t work.
Hope someone could help. Thanks
I’m not sure if this was caused by the most recent firmware update because the last time I checked it updated OK but sometime between yesterday and today suddenly became like this.
Hi, do you remember what the last version you upgraded to was?
You can first try repeatedly clicking Close or Open again (around 4–5 times) and check whether you can eventually enter the page normally. Please let me know the result.
unfortunately I dont remember the firmware version.
I did try closing and opening it quite a number of times. I’ve also tried powering it up on and off (it’s connected via power cable for now). Still not working.
I’ll go ahead and try a few more times now and will get back to you if anything changes.
thank you
i finally got to the factory reset screen. factory reseting now. thank you.
Update:
So the problem comes back whenever the NSPanel Pro restarts.
To fix it, the only way is to do a factory reset using the power-on / off for 5 times method.
I’ve reset it before connecting it my account, (QR code screen). I’ve reset it after connecting it to my account. I’ve tried updating the firmware.
Current firmware is 4.1.3 and it says it’s the latest version (however i can’t go to the next view when I tap “latest firmware”). Tapping on Release notes says 4.6.0 though.
not sure what else to try.
update 2:
finally found the firmware update in the device itself. it was set at 4.4.0 and i updated it to 4.6.0 and it seems to be working now.
i’ll monitor hopefully it’s totally fixed.
Great, thank you for the update and for keeping me informed.
Version 4.6.0 is currently the latest official release. If you encounter any issues, please don’t hesitate to contact me. I’m happy to help.
