NSPanel Pro v4.6.0 Officially Released: Local Web Portal, Local Setup, and Enhanced Integrations
Version: v4.6.0 (cumulative, includes v4.5.0 features)
Hi NSPanel Pro Users,
We are pleased to announce the official release of firmware version v4.6.0.
This update brings a new local web portal, broader Zigbee device support, improved Matter integrations, and more flexible local sub-device setup.
Before You Start
  • Please update the eWeLink App to v5.26.0 or later before upgrading your NSPanel Pro firmware.
  • The steps in this guide assume your NSPanel Pro has been updated to v4.6.0. Features introduced in v4.5.0 are marked where relevant.
Explore What’s New in v4.6.0
Core Features
Introduced Local Web Portal Support
NSPanel Pro can now be accessed over your local network via http://nspanelpro.local or its IP address.
For multiple devices, use http://nspanelpro-{deviceID}.local.
The local web portal supports selected setup and management features, including:
  • Device Setup & Smart Security
    • Add Zigbee and eWeLink-Remote sub-devices. Once added, they can be controlled from the NSPanel Pro screen.
    • Configure Smart Security and arm or disarm the system.
  • Integrations
    • Configure MQTT Broker to expose NSPanel Pro’s Zigbee sub-devices to Home Assistant.
    • Authorize Home Assistant so the supported Home Assistant entities can be included in Matter Bridge pairing.
    • Set up Matter Bridge pairing to expose the panel itself, along with eligible Zigbee sub-devices, eWeLink-Remote sub-devices, and Home Assistant entities to Matter-enabled platforms.
    • Link an eWeLink account to control devices remotely from the eWeLink App.
  • Personalization & Settings
    • Upload custom ringtones, screen savers, and wallpapers.
    • Configure Webpages, temperature and humidity data source, security code, Guest Mode, and Zigbee Modes.
Local Setup & Sub-device Control (v4.5.0)
Sub-devices now support local setup and operation directly on NSPanel Pro, skipping the eWeLink account linking.
BTHome Integration (v4.5.0)
NSPanel Pro can discover eligible BTHome devices via Bluetooth LE advertising and expose supported BTHome data to Matter-enabled platforms through Matter Bridge.
Supported BTHome data types include:
  • Sensor data: temperature, humidity, and illuminance
  • Binary sensor data
  • Event data
Additional Features
Expanded Zigbee Device Compatibility
Added support for more eligible Zigbee devices, including:
  • SONOFF MINI-ZB1GP / MINI-ZB1GSP: single-channel Zigbee smart switch with energy monitoring (v4.6.0)
  • SONOFF SNZB‑02B: temperature and humidity sensor (v4.5.0)
  • SONOFF SNZB‑06P24: 24 GHz presence sensor (v4.5.0)
  • SONOFF SNZB‑02M: temperature, humidity, and air pressure sensor (v4.5.0)
  • SONOFF BASIC‑ZB1GSP: DIN rail-mounted Zigbee smart switch (v4.5.0)
    Them are new SONOFF products which are coming soon, stay tuned!
Optimizations & Bug Fix
  • NSPanel Pro 86 Gen2 can now link with NSPanel Pro 86 and Pro 120 for unified control.
  • Streamlined the process of syncing Home Assistant devices to Matter-enabled platforms.
  • More Home Assistant synced entities now display the correct icons on NSPanel Pro for easier recognition.
  • Added “Tamper Alert” as a Smart Security alarm trigger for SONOFF SNZB-04P and SONOFF SNZB-04PR2.
  • Humidity readings for temperature and humidity sensors now display more accurately.
  • Fixed known bugs and improved system stability.
Feature Guides
To help you get started, we’ve included step-by-step guides for the main new features in this release: the local web portal access, local setup, and BTHome-to-Matter integration.
Note 1: The steps show where each setup is done, including operations in the eWeLink App and on the NSPanel Pro screen. Unless otherwise noted, they assume your NSPanel Pro has been updated to v4.6.0.
Tutorial 1: Access the Local Web Portal
This section walks you through accessing the local web portal, where you can manage supported features from your browser.
Before You Begin
Make sure your computer or mobile device is connected to the same local network as your NSPanel Pro.
Access Methods
Open a browser and use one of the following addresses:
  • Hostname (recommended): http://nspanelpro.local
  • IP Address: http://<NSPanel Pro IP>
  • Multiple Panels: http://nspanelpro-{deviceID}.local
Note 2: If you have multiple NSPanel Pro units on the same network, use the device-specific hostnameto access each panel individually.
Finding Your Device ID or IP Address
On the NSPanel Pro screen, swipe down from the top and go to:
Dropdown menu -> Settings -> About -> Device ID/IP.
Set A Password to Access Web Portal
The first time you open the local web portal, you will be asked to create a password for local portal access. For future visits, enter this password to sign in to the portal.
Portal Home Page
After signing in, the portal home page will load. You can manage supported features from your browser.
Tutorial 2: Local Setup & Sub-device Control (Available since v4.5.0)
This section guides you through adding sub-devices directly on NSPanel Pro without linking an eWeLink account first. Once added, you can view and control them from the NSPanel Pro screen.
Before You Begin
Make sure the sub-device is powered on and ready to enter pairing mode.
The pairing method may vary by device (e.g., pressing and holding a reset button, power cycling, etc.). Refer to the device manual if needed.
Pair a Sub-device on NSPanel Pro
Control the Sub-device After Setup
Once the sub-device has been added, you can view and control it from the NSPanel Pro screen.
Note 3: For remote control in the eWeLink App, sign in your eWeLink account from the local web portal or add NSPanel Pro to the app.
Tutorial 3: BTHome Integration via Matter Bridge (Available since v4.5.0)
This section shows how to add BTHome devices in the eWeLink App and make their supported data available through Matter Bridge.
BTHome is a lightweight Bluetooth LE advertising format commonly used by sensors and buttons to broadcast sensor readings, binary states, and events.
With v4.5.0 and later, NSPanel Pro can discover BTHome-compatible devices over Bluetooth and expose supported BTHome data to Matter-enabled platforms via Matter Bridge.
Note 4: Matter Bridge feature was introduced in v4.1.0. The BTHome integration described here is available since v4.5.0.
Prerequisites
Before you begin, please ensure the following:
  • NSPanel Pro has been updated to v4.5.0 or later.
  • Matter Bridge has already been set up on NSPanel Pro.
  • eWeLink App has been updated to v5.25.0 or later.
  • Bluetooth is enabled on your mobile device.
  • The BTHome device is nearby and broadcasting.
For Matter Bridge setup, see the previous guide: https://forum.ewelink.cc/t/nspanel-pro-v4-1-0-release-new-features-enhancements/206443
Scan for BTHome devices
In the eWeLink App, open the NSPanel Pro device settings and go to:
  • Navigate to Settings -> BTHome.
Note 5: Non-encrypted devices can be added directly. For devices that use encrypted BTHome data, have the 32-character hexadecimal bind key ready, which is usually provided in the device documentation or printed on the device.
Expose Supported BTHome Data to Matter
Once your BTHome devices have been scanned and added, you can start setting them up to expose the BTHome data to your added Matter platforms.
Continue in the eWeLink App:
  1. Navigate to Device Discovery -> Sync to Matter -> Matter Sync -> Select devices -> Confirm Sync.
  2. Check the box next to each device you want to include.
  3. Tap Confirm Sync to complete the setup.
What to Expect After Syncing
After successful sync:
  • Supported BTHome data will appear in your Matter platform, such as Apple Home, Google Home, Amazon Alexa, SmartThings, or Home Assistant, depending on platform support.
  • You can now view supported readings and events, including temperature, humidity, illuminance, binary sensor states, and event data, alongside your other Matter devices.
Bug Fixes & Gratitude
We’ve resolved several issues reported by the community, including improvements to stability, device compatibility, and interaction experience. Special thanks to all users who provided feedback – your input is invaluable in making NSPanel Pro better.
Conclusion
With v4.6.0 and the included v4.5.0 improvements, NSPanel Pro becomes even more powerful and flexible, with broader device compatibilities and better integration.
If you run into any issues, please share your feedback in the community forum or contact support. Thanks to everyone who shared feedback and helped us improve NSPanel Pro.
Thanks,
The NSPanel Pro Team
That’s all well and good, but we are still waiting for the promised ability to configure full local scenes in the NSPP via the web interfaces.
Hi, @Jojkoba
We are aware that you have been waiting for this functionality.
Internally, we are targeting an August–September release, but we still have several items under validation, so the exact date has not been finalised.
I will provide you with a more definitive timeline by the end of July. We appreciate your patience and continued attention to this matter.
My goal remains for the NSPP to be truly universal and usable in places with weak or no internet access, such as cabins and similar locations.
