Here you’ll find the release notes for NSPanel Pro firmware. We’ll update it with every new release so you always have the latest details.
How to Update
On the Nspanel Pro Device:
NSPanel Pro Top drop-down menu -> Settings -> About -> Software update. -
Via eWeLink App:
Open the eWeLink App, go to your NSPanel Pro device settings page, and check for firmware updates.
Release Tracks
We maintain two release channels:
Stable (Public) Release (Latest:
v4.6.0): Fully tested releases available to all users. Devices on the Stable channel receive these updates by default. -
Beta Releases (Latest:
-): No active beta at this time. The latest version has been released as a Stable version.
Pre-release builds for beta testing, providing early access to new features.
To join the Beta program, apply here: ** NSPanel Pro V4.x.x Beta Test Application Tool Now Open - NSPanel Pro - eWeLink Forum** Enrolled devices will receive Beta updates.
NSPanel Pro V4.6.0
New Features
Introduced Local Web Portal Support
NSPanel Pro can now be accessed over your local network via http://nspanelpro.local or its IP address.
For multiple devices on the LAN, use http://nspanelpro-{device ID}.local.
The local web portal supports selected setup and management features, including: -
Device Setup & Smart Security
- Add Zigbee sub-devices and eWeLink-Remote sub-devices.
- Configure Smart Security and arm or disarm the system.
Integrations
- Configure the MQTT Broker to sync Zigbee sub-devices to Home Assistant.
- Authorize Home Assistant connection and sync Home Assistant devices to Matter-enabled platforms.
- Link an eWeLink account for remote device control in the eWeLink App.
- Set up Matter Bridge pairing to sync NSPanel Pro itself, along with supported Zigbee sub-devices, eWeLink-Remote sub-devices, and Home Assistant entities, to Matter-enabled platforms.
Personalization & Settings
- Upload custom ringtones, screen savers, and wallpapers.
- Configure Webpages, temperature and humidity data source, security code, Guest Mode, and Zigbee Modes.
Expanded Device Compatibilities
- Added support for SONOFF MINI-ZB1GP / MINI-ZB1GSP single-channel Zigbee smart switches with electricity monitoring.
- Compatible with Shelly Ecowitt WS90 Zigbee weather station.
Optimizations & Bug Fixes
NSPanel Pro 86 Gen2 can now be linked to NSPanel Pro 86 and NSPanel Pro 120 for unified control.
Improved handling of expired shared devices on receiving panels, with clearer prompts and automatic removal.
Other NSPanel Pro Gen2 Optimizations:
- Optimized the Detach Relay Mode with more intuitive interactions.
- Improved channel capability and state mapping when syncing relay controls to Matter-enabled platforms.
Bug Fixes
- Fixed some known issues.
NSPanel Pro V4.5.3
Optimizations
- Streamlined Auto Discovery for Matter-compatible devices
- Optimized screen management for Matter devices on dedicated custom screens.
Bug Fixes
- Fixed known bugs and improved system stability.
NSPanel Pro V4.5.2
New Features
Expanded support for eligible Zigbee devices, including:
- Dual-Channel Smart Water Valve: SONOFF SWV-ZF2E/SWV-ZF2U
- PIR Motion Sensor: SONOFF SNZB-03PR2
NSPanel Pro V4.5.1
Bug Fixes
NSPanel Pro V4.5.0
New Features
Sub-devices now support local setup and operation directly on NSPanel Pro, skipping the eWeLink account linking.
Added support for SONOFF SNZB-02B, SONOFF SNZB-06P24, SONOFF SNZB-02M, and SONOFF BASIC-ZB1GSP.
BTHome Integration: Added support for discovering eligible BTHome devices and exposing supported BTHome data to Matter-enabled platforms via Matter Bridge.
Supported data types include:- Sensor data: temperature, humidity, and illuminance
- Binary sensor data
- Event data
Added “Tamper Alert” as a Smart Security alarm trigger for SONOFF SNZB-04P and SONOFF SNZB-04PR2.
Streamlined the process of syncing Home Assistant devices to Matter-enabled platforms.
More Home Assistant synced entities now display the correct icons on NSPanel Pro for easier recognition.
Humidity readings for temperature and humidity sensors now display more accurately.
NSPanel Pro V4.4.6
New Features
- Expanded Device Support: Added support for SONOFF Hydro ONE Zigbee Smart Water Valves (SWV-ZFU / SWV-ZFE) and SONOFF Hydro ONE Lite Zigbee Smart Water Valves (SWV-ZNU / SWV-ZNE).
Bug Fixes & Improvements
System & Connectivity
Connectivity Stability: Fixed an issue where some Zigbee sub-devices could unexpectedly go offline.
Unresponsive Issues: Resolved several issues that could cause NSPanel Pro to become unresponsive in certain scenarios.
MQTT Reconnection: Fixed an issue where the MQTT connection to Home Assistant might fail to reconnect automatically.
OTA Updates: Addressed an issue where OTA updates could fail for certain sub-devices.
Display & User Interface
Navigation Bar: Fixed a display issue on NSPanel Pro 120 where the navigation bar appeared incorrectly in Landscape mode after a reboot.
Call Screen: Resolved a UI glitch where the call screen persisted in the recent apps view even after a call ended.
Webpages Management: Resolved a video URL parsing issue to ensure saved pages are correctly recognized and remain manageable.
Sensor Accuracy: Fixed an issue where comfort status for certain temperature and humidity sensors was displayed incorrectly.
Lighting Control: Resolved a color adjustment issue for certain previously added smart lights.
NSPanel Pro V4.4.0
New Features
Expanded the set of NSPanel Pro capabilities exposed as Home Assistant entities via MQTT broker. You can now control the following entities from Home Assistant:
Start/stop microphone recording on NSPanel Pro.
Play audio on the NSPanel Pro speaker.
Enable/disable Wake on Proximity to wake the NSPanel Pro screen when you approach.
Added support for IKEA E2112 Zigbee air quality sensor.
Added on-screen control support for eligible Wi-Fi devices, including:
SONOFF AWF-07P
SONOFF SAWF-08P
SONOS Speakers (S2 Sonos systems only)
Added an option to configure extra travel time for SONOFF MINI-ZBRBS in the eWeLink App to help ensure full open/close with manual calibration.
Added Adaptive Mode for SONOFF TRVZB, configurable in the eWeLink App, to help maintain a more stable room temperature.
Added Do Not Disturb mode with scheduling and per-category notification exceptions, reducing unwanted interruptions while still allowing important alerts.
NSPanel Pro can now use personal images uploaded via the eWeLink App for its screen saver.
Optimizations
Central Heating Feature Improvements:
Room list and device location changes now update automatically on NSPanel Pro (no reboot required).
Connected boiler/valve actuators are turned off automatically when removing a Central Heating system or a room thermostat, preventing them from being left on.
Related central heating systems or room thermostats are marked as “Invalid” when a connected device is removed, moved, or disconnected.
Improved multi-channel device tile with more intuitive interactions.
Access to features, including Matter Bridge, F-Droid, and Apps, is now disabled in Guest Mode.
Camera view now supports switching between Landscape and Portrait orientations.
Support syncing eWeLink-Remote device status even when the screen is off.
Added a Block Firmware Updates toggle to stop automatic firmware update checks and downloads.
Bug Fix
- Fixed an issue where the Home App selection in NSPanel Pro wasn’t applied as expected after it was configured in Android system settings.
Note: This version was a beta rollout for selected units.
NSPanel Pro V4.3.2
Optimizations
- Improved device tiles with more intuitive tap interactions.
Bug Fixes
- Fixed various known issues.
NSPanel Pro V4.3.0
New Features
NSPanel Pro can now act as a Matter Bridge to sync Home Assistant entities to Matter-enabled platforms.
NSPanel Pro can now expose its capabilities as entities to Home Assistant via MQTT Broker, configured in the eWeLink App, including:
- NSPanel’s speaker is now exposed in Home Assistant, enabling startup volume adjustments.
- Added support for adding NSpanel Pro’s Zigbee sub-devices via Home Assistant.
- Supports setting the screen to awake/sleep and adjusting brightness from Home Assistant.
- Smart Security can now be armed and disarmed from Home Assistant.
- A list of Zigbee devices synced from NSPanel Pro is now available in Home Assistant
Added support for SONOFF MINI-ZB2GS with stepping control, configurable in the eWeLink App, allowing external switch press actions to cycle through a preset step sequence of relay states.
Notifications on NSPanel Pro now support custom ringtones and messages for Smart Security and Smart Scene events.
Added an option to show the live camera feed on NSPanel Pro when triggered as a scene action.
The Central Heating screen can now be enabled via the eWeLink App and supports reordering.
Optimizations
Improved device tiles with clearer status and more intuitive tap interaction.
Consistent screen sleep/wake and screensaver behavior across all apps.
Added an option to mute the startup sound.
Improved TRV support on NSPanel Pro, including:
- Display and control in the thermostat screen view.
- Enhanced tile information for current status and target temperature.
Reboots are no longer necessary for smoothly switching between Zigbee Hub Mode and Zigbee Router Mode.
Expanded support for custom ringtones, allowing up to 5 uploaded ringtones.
Temperature adjustments for Thermostat are now more precise when configured in the eWeLink App.
Optimized the layout of NSPanel Pro’s control page in eWeLink App for a clearner view.
Bug Fixes
NSPanel Pro V4.2.0
New Features
- Added an “Apps” menu item in the top drop-down menu for quickly switching between apps installed from F-Droid.
- Added support for the following eligible devices:
- SONOFF SNZB-02DR2
- SONOFF MINI-ZBDIM MINI
- SONOFF MINI-DIM MINI
- SONOFF CAM-B1P
- SONOFF SNZB-01M
- SONOFF SNZB-04PR2
- Bypass tricky on-screen input! Configure IP cameras conveniently in the eWeLink App.
Optimizations
- Matter Bridge now supports syncing eligible Wi-Fi devices linked to the same eWeLink account as NSPanel Pro to the added Matter platforms for control, including:
- POWR
- POWCT
- S60ZBTPF/S60ZBTPG
- NSPanel
- DUALR3 Lite
- M5
- B05-BL-A60
- B05-BL-A19
- iFan04
- B02
- D1
- T5
- SPM-4Relay
- B02-BL-A60
- B02-BL-A19
- DW2-Wi-Fi
- L2
- L3-5M
- L3-5M-P
- The NSPanel Pro App now supports persistent background activity.
- Screen reordering is now supported for all custom screens.
- Multi-channel devices now show each channel as a separate tile on NSPanel Pro screens when linked via the eWeLink App.
- Added two new temporary modes for SONOFF TRVZB:
- Boost Mode: Heats the room quickly for a short period.
- Temperature Override Mode: Temporarily maintains a user-set temperature.
- Added support for deleting MQTT Broker configurations when syncing Zigbee sub-devices to Home Assistant over MQTT.
- Improved 12-hour time format display.
- Improved the date format shown on the Screen Saver.
Bug Fixes
NSPanel Pro V4.1.5
New Features
- OTA Updates via App: Support for firmware updates through the eWeLink App.
- Update Control: Option to disable automatic firmware downloads.
Optimizations
- Automatic storage check before downloading firmware.
Note: This version is now a stable public release, available to all users.
NSPanel Pro V4.1.0
New Features
- Initial Matter Bridge support for Zigbee sub-devices.
- Support for syncing Zigbee devices to Home Assistant.
- Added support for SONOFF MINI-ZB2GS-L.
For older releases and FAQs, see: SONOFF NSPanel Pro Version Update Information and FAQ link.
This thread is maintained by the NSPanel Pro team. For version-specific questions, drop them in the comments!
