NSPanel Pro v4.4.0 Officially Released: New Features & Enhancements
Dear NSPanel Pro Users,
Thank you for your continued attention and support! We are pleased to announce that the NSPanel Pro V4.4.0 firmware has been officially released. This update focuses on strengthening integration with Home Assistant, bringing smarter thermostat controls, deeper personalization, and numerous usability enhancements—all designed to make your smart panel more powerful and intuitive.
New Features Overview
Core Features
  • Zigbee Improvement in Performance and Compatibility
    The built-in Zigbee NCP firmware will be upgraded to 8.x, and we’ll fully incorperate zigbee-herdsman and zigbee-herdsman-converters to better support 3rd-party and non-standard Zigbee devices.
  • Enhanced Home Assistant Integration via MQTT
    NSPanel Pro now exposes more of its native capabilities to Home Assistant, enabling you to:
    • Start/stop microphone recording.
    • Play audio through the NSPanel Pro speaker.
    • Enable/disable Wake on Proximity (screen wakes when you approach).
These new entities can be used in automations, dashboards, and scenes, further tightening the bond between NSPanel Pro and your smart home.
Additional Features
  • New Device Support
    • Zigbee: IKEA E2112 air quality sensor.
    • Added on-screen control support for eligible Wi-Fi devices, including:
      • SONOFF AWF-07P
      • SONOFF SAWF-08P
      • SONOS Speakers (S2 Sonos systems only)
  • Do Not Disturb Mode
    Added Do Not Disturb mode with scheduling and per-category notification exceptions, reducing unwanted interruptions while still allowing important alerts.
  • Personal Image Screen Saver
    NSPanel Pro can now use personal images uploaded via the eWeLink App for its screen saver.
  • Added Adaptive Mode for SONOFF TRVZB, configurable in the eWeLink App, to help maintain a more stable room temperature.
  • Central Heating System Improvements
    • Room list and device location changes now update automatically on NSPanel Pro – no reboot required.
    • Connected boiler/valve actuators are turned off automatically when removing a Central Heating system or a room thermostat, preventing them from being left on.
    • Related central heating systems or room thermostats are marked as “Invalid” when a connected device is removed, moved, or disconnected.
  • UI/UX Optimizations
    • Improved multi-channel device tile with more intuitive interactions.
    • Camera view now supports switching between Landscape and Portrait orientations.
    • Access to features, including Matter Bridge, F-Droid, and Apps, is now disabled in Guest Mode.
  • Block Firmware Updates toggle:
    Added a Block Firmware Updates toggle to stop automatic firmware update checks and downloads.
Bugfixes
Several known issues have been fixed, improving system stability.
This release implements some of the features outlined in our product roadmap. Please refer to NSPanel Pro Roadmap and Co-Created Future - NSPanel Pro - eWeLink Forum for more details.
Detailed Operation Tutorials
To help you quickly get started with the new features, we’ve provided detailed step-by-step guides for each major feature, including both eWeLink App and NSPanel Pro screen operations. Please ensure your NSPanel Pro has been upgraded to v4.4.0
Note:
  1. v4.4.0 is a beta release for selected devices. If you would like to experience the latest features, please join through the NSPanel Pro v4.xx Beta Test Application Tool.
  2. Please ensure your App version is v5.22.2or above.
The current eWeLink App v5.22.2 was submitted to the Google Play Store for review on February 10th and is expected to support updates in about a week.
Tutorial 1: Zigbee Improvement in Performance and Compatibility
No operation required.
Tutorial 2: Enhanced Home Assistant Integration via MQTT
You can now play audio directly on NSPanel Pro from Home Assistant — either by selecting a pre-uploaded audio file or entering a URL to stream.
Note: If you have already configured an MQTT Broker via the eWeLink App before this version, after upgrading to v4.4.0, NSPanel Pro will automatically connect to the configured Home Assistant.
App Operation Steps:
Please refer to: https://forum.ewelink.cc/t/nspanel-pro-v4-1-0-release-new-features-enhancements/206443
  1. In the App, go to NSPanel Pro > Device Settings > Home Assistant > Click Get Started. After completing the MQTT Broker configuration,NSPanel Pro will automatically connect to the Home Assistant platform previously configured.
  2. Once connected, you can view and control NSPanel Pro in Home Assistant. The newly added supported functions include:
    • Button: Mic Start/Stop Recording – Start/Stop recording.
    • Select: Spkr Select NSPanelPro Audio – Select audio to play on the speaker.
    • Button: Spkr Play/Stop – Start/Stop audio playback on NSPanel Pro speaker.
    • switch: Wake on Proximity – Enable/disable.
      These entities can be used in Home Assistant automations.
Tutorial 3: Setting Up Do Not Disturb Mode
  • App Operation Steps:
    1. Navigate to NSPanel Pro > Device Settings > Do Not Disturb.
    2. Toggle Do Not Disturb on.
    3. Schedules: Set start/end times for automatic activation.
    4. Notification Exceptions: Select which categories (e.g., Security Alarm, Device Status Changes…) are allowed to wake the screen or play alert sounds during Do Not Disturb mode.
    5. Save settings.
  • NSPanel Pro Screen Operation Steps:
    On the panel, only “Do Not Disturb mode” can be enabled or disabled; configuration options are not directly supported on the device screen.
Bug Fixes & Gratitude
In the v4.4.0 release, we’ve fixed several issues reported by our community. Special thanks to all users who took the time to share feedback on our forum. Your reports help us identify and resolve issues quickly, making NSPanel Pro better for everyone.
Notable fixes include:
  • Fixed an issue where the Home App selection in NSPanel Pro wasn’t applied as expected after it was configured in Android system settings.
  • Camera orientation switching is more reliable.
  • eWeLink‑Remote status syncs properly even when the screen is off.
We sincerely thank all users who reported issues! If you encounter any new problems after upgrading, please feel free to post in the forum or contact our support team. Your feedback is the driving force behind our progress.
Conclusion
V4.4.0 makes your NSPanel Pro more powerful, open, and user-friendly with deeper Home Assistant integration, smarter heating controls, richer personalization, and a host of thoughtful optimizations.
If you experience any difficulties during the upgrade or while using the new features, please join the discussion on our community forum. Your insights are invaluable and help shape the future of NSPanel Pro.
Thank you for your ongoing support.
The NSPanel Pro Team
[Release Date]
Hello again.
After the last update to version 4.4.0, I noticed:
one panel started to heat up and make sounds like tapping on the screen (10022e4e38).
A similar situation, but without heating, occurred with panels 10022e4eba and 10022e4ebe.
Hi guys
Thank you for the update and to listen to all our requests. I know the system is not perfect yet but we getting there. I personally use home assistant as my main app as I have many devices but I love the nspanel screensaver, with latest version I can now have the screensaver active and wake up the screen in home assistant mode just by waving my hand I also made an automation in HA to wake screen up if door bell or any other cameras sensor triggers off. @jojo One question that I have not understood and I need help to setup my Sonos speakers I see you guys added support for this but no too sure how to pair them.
Again thank you for your work
Hello. I’m testing the new TRVZB adaptive mode, but my heating isn’t turning off when it should. Currently my heating is set at 19°C, but two rooms are at 20°C and still heating. To stop this, I had to turn the heating off and then enable the schedule again.
This happened again today. I’ve submitted feedback.
I appreciate the NS Panel Pro 120; I hope the MQTT instability issue has been resolved. Adding the proximity sensor to Home Assistant is wonderful. Is it possible to increase the detection distance from 30cm to 60cm? My panel is in a hallway, and a distance of 60cm would be perfect for detecting people passing by. Keep up the good work.
As I have seen for now, we can o lo playback the audio files that had been recorded from the mic record button. Is It posible to upload other files to nspp? Or Is It posible to set an soeaker audio address for an audio file stored in my ha OS?
Hello guys, First of all, thank you in advance for your effort and for the update.
After the update, the first issue I experienced is that the NSPanel Pro started making strange “tick tick tick” sounds. This happens whether the screensaver is active, while navigating the menus, or even when I’m watching the cameras.
When this occurs, restarting the device sometimes stops the noise temporarily, but lately this issue has become more frequent and it has started to bother me.
I have just sent you feedback about this issue as well.
I’m hearing tap sound, too. I think thats because of the new poximity wakeup feature. (I don’t know if there is a real sensor or they just do some light sensor magic.)
When connecting the panel via mqtt to home assistant, you’re getting a new control and sensor for this feature.
When the control is on and the display is off, the display wakes up when I’m near to it. And I can hear the tap sound. When the control off, the display stays off and no tap sound appears.
I hate the sound, whether it’s from taping or waking up. I was happy to discover that it can be disabled (Settings > Advanced Settings > Sound > Touch Sounds).
How can I add my Sonos speakers? Is there a step by step guide for this?
Is the new feature that the LCD is still lit and the speaker is popping!
I was hearing that whenever my hand went near the screen. I’ve turned off the ‘Wake on Proximity’, and it’s stopped. Mine seemed to be very sensitive, as it turned the screen on when I entered the room.
I also have this “clicking” sound. When I disable “Wake on Proximity,” it goes away. I suspect these are the touch tones from Android when you tap.
And in Home Assistant, its flapping :slight_smile:
Exactly. I think when “Wake on” is enabled, a tap is simulated to activate the display (or keep it activated). Thats why we hear the tap sound.
When you’ve disabled the sound (like I discribed above), the “Wake on” works like before but the sound doesn’t appear.
What does turbo do?
Did you manage to play sound on the device?
Thank you :slight_smile:
hello sonoff staff dear,
I have nspanel pro ver 3.4.1
but, my device not responce via running system update
can you help me?
my device id 10023a837c
@mario.georgiev For now, you can bind Sonos by adding a third-party service in eWeLink Web. Once successfully linked, you can sync your Sonos speakers to NSPanelPro via the eWeLink app for use (Sonos service binding is expected to be supported in the next version of the app).
Another important note: This feature requires a membership on the web platform.
Hi, you can obtain the latest version through this beta application tool.
I understand your usage scenario. However, the proximity sensor currently used by NSPanelPro reports changes only when an object approaches, but it does not report the specific distance. Therefore, for now, it is not possible to restrict this function based on distance.
@chriss2 @Radaristanbul @danielk117 @Stophammer @derPate1989
Thank you for your feedback. This is indeed an issue (it may have been overlooked during development due to the noisy office environment). We plan to optimize it in the next version of NSPanelPro.
As @danielk117 mentioned, for now, you can go to Settings > Advanced Settings > Sound > Touch Sounds to disable it and resolve the issue.Thank you for the suggested solution.
