- Proximity wake-up doesn’t work for me ( tested on Sonoff app, i suspect than HA doesn’t work for now )
- Checked Proximity sensor tested with testing app, the proximity sensor work well in range 0-20cm from NSpanel. ( i thinked the sensor have ability to work in long distance up to 60cm 1m …, to wake screen when you are around, but not to be very close )
also @DamienCH
I am sorry to say NSPanel Pro has built-in ICC light sensor but no proximity sensor. The test app works by checking a significant change in illumination. We could implement a feature called:
- Wave your hand to turn on the display: To turn on the display of NSPanel Pro, you need to tap on the screen first. Is there a better way? One of our dear users showed us the magic: wave hand in front of NSPanel Pro, the display will be automatically turned on.
If you go close enough to NSPanel Pro which actually blocks the light, the screen will be turned on automatically.
- i suspect found an bug : when you uncheck “ auto download update” you can’t update manually the new firmware. the row-circle button only check the firmware available, but nothing more, for donwloading update, i needed to check “ auto download” to have ability to install the new firmware.
Oh, sorry for the misunderstanding. This is the intended behavior. Maybe the title Auto Firmware Download is a little misleading.
